Hello
I come n to you because I little demal with the operation of the control of the Volume on Audirvana Studio
I have a control Pc under Windows 11 where Audirvana Studio is installed, it sends the stream Via Kernel Streaming to a second PC under Linux (Gentooplayer) for HQPE and it sends the Stream in USB to a DAC Holo Spring 3 level 2
concerning the control of the Volume by Audirvana , there are 2 sections
- Next to “Volume Equalization” is “Inactive Volume Control”??
- Then to the left of “DAC Input”, there is “Active Volume Control” ??
just below, a small speaker with a -+ bar that is 100%
I’m a little confused
I act on the volume control in the HQPE parameters for now because the volume level at the amp is too important
thank you for your answers
cpasmoi
