I can’t seems to turn on volume control with my Chord Mojo. I know it works normally without Audirvana, but with it, the volume is set to 100% max, and I could only control it via the amp/dac itself. Is it suppose to be this way? Even the windows volume control doesn’t do anything. The software volume control setting won’t let me toggle it on at all. Anyway to enable it? Debug logs below.
I’m close to buying this software, the only problem is the Volume Control and the lack of Spotify for it to be a really killer app atm.
Debug Log
Audirvana 3.5.13
AUTO: C:\Users\Secret\Desktop\Music
Library database path: C:\Users\Secret\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4970MB
Local Audio Engine:WASAPI
Digital Output (Chord Async USB 44.1kHz-768kHz)
Model UID:Digital Output (Chord Async USB 44.1kHz-768kHz)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{618162ca-3306-41b5-9a6c-a718bf0d8fe5}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 16bits Integer, 4 bytes per frame 44.1kHz
Digital Output (Chord Async USB 44.1kHz-768kHz) Manufacturer:
Model UID:Digital Output (Chord Async USB 44.1kHz-768kHz) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{618162ca-3306-41b5-9a6c-a718bf0d8fe5}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Simple stereo device: No
2 ch Integer PCM 24bit little endian 352.8kHz
2 ch Integer PCM 24bit little endian 384kHz
2 ch Integer PCM 24bit little endian 705.6kHz
2 ch Integer PCM 24bit little endian 768kHz
Local devices found : 5
Device #0: Realtek Digital Output (Realtek High Definition Audio) Manufacturer: Model UID: Realtek Digital Output (Realtek High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{3acb5f66-546b-4886-bfd8-feba468eee34}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Speakers (G560 Gaming Speaker) Manufacturer: Model UID: Speakers (G560 Gaming Speaker) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{0ec53023-da0d-4aca-932f-2a38c36d7d43}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: SONY TV (2- NVIDIA High Definition Audio) Manufacturer: Model UID: SONY TV (2- NVIDIA High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{160ae4cb-876b-4722-9200-3b1e9b04fdd5}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #3: Z321QU (2- NVIDIA High Definition Audio) Manufacturer: Model UID: Z321QU (2- NVIDIA High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{17cd440d-51f6-4908-b118-6f8bab213eee}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #4: Digital Output (Chord Async USB 44.1kHz-768kHz) Manufacturer: Model UID: Digital Output (Chord Async USB 44.1kHz-768kHz) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{618162ca-3306-41b5-9a6c-a718bf0d8fe5}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
UPnP devices found : 1
Device #0BRAVIA KDL-32W674A UID: uuid:00000000-0000-1010-8000-3c0771cbf18e Location: http://192.168.0.186:52323/dmr.xml
