Hi,
I’m running Audirvana with Topping E30 USB DAC in MacOS.
DAC is set to pure DAC mode. I connect active speakers to DAC analog output.
Software volume control is OFF in Audirvana, the volume bar still shown (I’d assume it controls MacOS master volume for my DAC) - when I set it to 100% I hear some distortions in audio output. If I set volume to 75% sound is clean. If I use some other MacOS audio player I have no issue like that at 100% volume set in MacOS for my DAC. So, that’s not my speakers.
I tried different settings (disable Exclusive mode, Integer mode) - that didn’t help.
Any advice how to get rid of distortions at 100% volume in Audirvana? Thanks,
My debug info:
Audirvana Mac Version 3.5.41 (3571)
macOS 10.15.7 with 32768MB RAM
SW volume control: ON
Sync list: 2 folders
AUTO: /Volumes/music/
AUTO: /Volumes/music-1/
Library database path: /Users/dmitry/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 2340MB
E30
Model UID:E30:152A:8750
UID:AppleUSBAudioEngine:Topping:E30:14410000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 88.2kHz
Active Sample Rate: 88.2kHz
Hog Mode is on
ID 0x7f E30 Manufacturer:Topping
Model UID:E30:152A:8750 UID:AppleUSBAudioEngine:Topping:E30:14410000:1
Audio buffer frame size : 231 to 4096 frames
Stream ID 0x80 2 channels starting at 1
30 virtual formats:
40 physical formats
Local devices found : 4
Device #0: ID 0x62 DELL U2720Q Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:30001:0:{AC10-41B5-4144574C}
Device #1: ID 0x7f E30 Manufacturer: Topping Model UID: E30:152A:8750 UID: AppleUSBAudioEngine:Topping:E30:14410000:1
Device #2: ID 0x4b External Headphones Manufacturer: Apple Inc. Model UID: Codec Output UID: BuiltInHeadphoneOutputDevice
Device #3: ID 0x56 MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
