Hello.
The current version of Audirvana has come serious issues with the volume slider, which makes the software pretty much useless to me at the moment.
With Software Volume Control disabled, the volume slider bugs out when using the macOS volume keys, meaning it suddenly snaps to -∞ dB. There is still sound, but it’s very low. It’s possible to slide the volume back up with the mouse however, but as soon as I use the keys again, it snaps back to -∞ dB, no matter if I press the volume up or volume down.
With Software Volume Control enabled, I can use the keys, but the sound is very low, even at max volume (0.0 dB).
Also, in both modes, this volume behavior also affects macOS itself, making me unable to use the volume media keys outside Audirvana Studio. Not even the macOS volume OSD shows up anymore while Studio is running, even if Studio is running/minimised.
The ‘Maximum Audio Volume’ level is set to max.
Restarting Audirvana Studio/macOS does not remedy the problem.
In all honesty, this issue along with the uneven UI, makes Audirvana Studio feel like a beta product still. To me, Audirvana Studio is even worse than 3.5.
I’m seriously considering cancelling my subscription and go back to VOX. I lose the library functionality, but at least VOX has a more mature UI and there are no crippling bugs like the one mentioned above. Audirvana Studio is simply the buggiest music player ever used (duplication of albums/volume problems/UI inconsistencies). It seems rushed and unfinished.
DEBUG INFO:
Audirvana Studio 1.8.5 (10805)
macOS 10.15.7 with 24GB physical RAM
Replay Gain: by track
Listening on 127.0.0.1 on port 50690
Max. memory for audio buffers: 21504MB
Exclusive access: Disabled
APPLE INC. BUILT-IN OUTPUT
Model UID:AppleHDA:7
UID:AppleHDAEngineOutput:1B,0,1,2:0
ID 0x39 Built-in Output
Model Name: Apple Inc. Built-in Output
Model UID: AppleHDA:7
Stream ID 0x3a 2 channels starting at 1
4 virtual formats:
16 physical formats
Device #0: ID 0x39 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:7 UID: AppleHDAEngineOutput:1B,0,1,2:0 Model Name: Apple Inc. Built-in Output
Device #1: ID 0x2b BoomAudio Manufacturer: Global Delight Technologies Pvt. Ltd. Model UID: GDAudioDevice_ModelUID UID: GDAudioDevice_UID Model Name: Global Delight Technologies Pvt. Ltd. BoomAudio
