hello, I updated Volumio to version 3, Audirvana no longer works, it does not load the songs, help me, thanks, Volumio is on Raspberry and connected to Macintosh MA5300 with USB
Hello,
I have Audirvana 3.5 and volumio 3 in wifi connection. Everything works for me.
Have you defined a fixed ip for volumio? This has been mentioned in previous posts.
hello, I try thanks
no, it doesn’t work, it loads a song and it freezes, also the time bar doesn’t work
macOS 12.0.1 with 16384MB RAM
Registered to maurilio gelati
SoX custom frequencies
AUTO: /Volumes/Lacie/iTunes/iTunes Media/Music
Library database path: /Users/mauriliogelati/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: Volumio-UPnP/AV Model UID:JF Light Industries Volumio-UPnP/AV UID:uuid:548a2cb5-2925-37ea-1818-dca6324b218b
UPnP device at http://192.168.188.57:49152/uuid-548a2cb5-2925-37ea-1818-dca6324b218b/description.xml
ID 0x0 Volumio-UPnP/AV Manufacturer:JF Light Industries
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::application/flac:
http-get::application/x-flac:
http-get::application/ogg:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/aif:
http-get::audio/aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/matroska:
http-get::audio/x-matroska:
http-get::audio/mp1:
http-get::audio/mp3:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-ape:
http-get::audio/ape:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::audio/x-wavpack:
http-get::video/mp4:
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
33 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 705.6kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 768kHz
0 physical formats
NrTracks: 1
MediaDuration: 0:06:58
CurrentURI: http://192.168.188.22:49152/audirvana/audio_1_32.wav
CurrentURIMetadata:
dc:titleThe Court of the Crimson King (Live)</dc:title>
dc:creatorKing Crimson</dc:creator>
upnp:artistKing Crimson</upnp:artist>
upnp:genreRock</upnp:genre>
upnp:albumArtURIhttp://static.qobuz.com/images/covers/25/16/0633367881625_600.jpg</upnp:albumArtURI>
upnp:albumRadical Action To Unseat the Hold of Monkey Mind (Live)</upnp:album>
upnp:originalTrackNumber6</upnp:originalTrackNumber>
nextURI: http://192.168.188.22:49152/audirvana/audio_0_33.wav
nextURIMetadata:
dc:titleShadow of the Hierophant</dc:title>
dc:creatorSteve Hackett</dc:creator>
upnp:artistSteve Hackett</upnp:artist>
upnp:genrePop</upnp:genre>
upnp:albumArtURIhttp://static.qobuz.com/images/covers/52/58/0886443635852_600.jpg</upnp:albumArtURI>
upnp:albumGenesis Revisited II</upnp:album>
upnp:originalTrackNumber11</upnp:originalTrackNumber>
PlayMedium: HDD
<?xml version="1.0"?> 1 0 TransportState no string STOPPED PLAYING TransportStatus no string OK ERROR_OCCURRED PlaybackStorageMedium no string PossiblePlaybackStorageMedia no string RecordStorageMedium no string PossibleRecordStorageMedia no string CurrentPlayMode no string NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL RANDOM DIRECT_1 NORMAL TransportPlaySpeed no string 1 no RecordMediumWriteStatus string CurrentRecordQualityMode no string PossibleRecordQualityModes no string NumberOfTracks no ui4 0 2000 1 CurrentTrack no ui4 0 2000 1 CurrentTrackDuration no string CurrentMediaDuration no string CurrentTrackMetaData no string CurrentTrackURI no string AVTransportURI no string AVTransportURIMetaData no string NextAVTransportURI no string NextAVTransportURIMetaData no string RelativeTimePosition no string AbsoluteTimePosition no string RelativeCounterPosition no i4 AbsoluteCounterPosition no i4 CurrentTransportActions no string LastChange yes string A_ARG_TYPE_SeekMode no string ABS_TIME REL_TIME A_ARG_TYPE_SeekTarget no string A_ARG_TYPE_InstanceID no ui4 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActionsCurrent device RootDevice description:
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 Volumio-UPnP/AV JF Light Industries https://framagit.org/medoc92 UPnP front-end to MPD UpMPD 42 https://framagit.org/medoc92/upmpdcli/code/ upmpdcli version 1.5.8 libupnpp 0.20.2 image/png 64 64 32 /uuid-548a2cb5-2925-37ea-1818-dca6324b218b/icon.png /uuid-548a2cb5-2925-37ea-1818-dca6324b218b/presentation.html uuid:548a2cb5-2925-37ea-1818-dca6324b218b urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /uuid-548a2cb5-2925-37ea-1818-dca6324b218b/urn-schemas-upnp-org-service-AVTransport-1.xml /uuid-548a2cb5-2925-37ea-1818-dca6324b218b/ctl-urn-schemas-upnp-org-service-AVTransport-1 /uuid-548a2cb5-2925-37ea-1818-dca6324b218b/evt-urn-schemas-upnp-org-service-AVTransport-1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /uuid-548a2cb5-2925-37ea-1818-dca6324b218b/urn-schemas-upnp-org-service-RenderingControl-1.xml /uuid-548a2cb5-2925-37ea-1818-dca6324b218b/ctl-urn-schemas-upnp-org-service-RenderingControl-1 /uuid-548a2cb5-2925-37ea-1818-dca6324b218b/evt-urn-schemas-upnp-org-service-RenderingControl-1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /uuid-548a2cb5-2925-37ea-1818-dca6324b218b/urn-schemas-upnp-org-service-ConnectionManager-1.xml /uuid-548a2cb5-2925-37ea-1818-dca6324b218b/ctl-urn-schemas-upnp-org-service-ConnectionManager-1 /uuid-548a2cb5-2925-37ea-1818-dca6324b218b/evt-urn-schemas-upnp-org-service-ConnectionManager-1UPnP devices found : 2
Device #0: ID 0x0 TV Monica UID: uuid:c4d5833a-5a42-8502-3074-835670d3f29c Location: http://192.168.188.45:1456/
Device #1: ID 0x0 Volumio-UPnP/AV UID: uuid:548a2cb5-2925-37ea-1818-dca6324b218b Location: http://192.168.188.57:49152/uuid-548a2cb5-2925-37ea-1818-dca6324b218b/description.xml
Max. memory for audio buffers: 7504MB
Device #0: ID 0x31 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:57 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
I am on windows 10.
Reflash volumio. If it worked with version 2, there is no reason why it should not work with v3.
already done, it doesn’t work, great with moode
I prefer Volumio, easier to configure, if I can’t I will use moode
