I have installed Audirvana 3.5.50 (3580) on my M2 Max Mac Studio with Sonoma, the Library is in two local external HD not on a NAS or network and i try to use an exetrnal DAC.
Audirvana have a strange behaviour. First Scan the Library ( that is very big) every time is launched and after that (that is a problem itself) stucks when play starts showing “Loading first track…”.
Yesterday i mas able to start a play but Audirvana crashes after some minutes.
Please help me to solve the problem. Debug Info Appended.
Thanks a lot.
Best Regard
Vincenzo Corrado
Debug Info:
macOS 14.1.2 with 65536MB RAM
Registered to Vincenzo Corrado
Sync list: 2 folders
AUTO: /Volumes/MyMusic2/MusicLibrary2
AUTO: /Volumes/MyMusic/MusicLibrary1
Library database path: /Users/vincenzo/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
TIDAL: Connected as PREMIUM
Preferred device: Volumio-UPnP/AV Model UID:JF Light Industries Volumio-UPnP/AV UID:uuid:548a2cb5-2925-37ea-1818-dca6322e5686
UPnP device at http://192.168.0.120:49152/uuid-548a2cb5-2925-37ea-1818-dca6322e5686/description.xml
ID 0x0 Volumio-UPnP/AV Manufacturer:JF Light Industries
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::application/flac:
http-get::application/x-flac:
http-get::application/ogg:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/aif:
http-get::audio/aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/matroska:
http-get::audio/x-matroska:
http-get::audio/mp1:
http-get::audio/mp3:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-ape:
http-get::audio/ape:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::audio/x-wavpack:
http-get::video/mp4:
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
14 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 0:00:00
CurrentURI: http://192.168.0.30:49152/audirvana/audio_0_0.wav
CurrentURIMetadata:
dc:titleLet It Snow! (10th Anniversary)</dc:title>
dc:creatorMichael Bublé</dc:creator>
upnp:artistMichael Bublé</upnp:artist>
upnp:genre</upnp:genre>
upnp:albumArtURIhttp://resources.tidal.com/images/e1ca7712/91a3/4b62/b03d/16b0e827fcf8/640x640.jpg</upnp:albumArtURI>
upnp:albumLet It Snow! (10th Anniversary)</upnp:album>
nextURI:
nextURIMetadata:
PlayMedium: HDD
<?xml version="1.0"?> 1 0 TransportState no string STOPPED PLAYING TransportStatus no string OK ERROR_OCCURRED PlaybackStorageMedium no string PossiblePlaybackStorageMedia no string RecordStorageMedium no string PossibleRecordStorageMedia no string CurrentPlayMode no string NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL RANDOM DIRECT_1 NORMAL TransportPlaySpeed no string 1 no RecordMediumWriteStatus string CurrentRecordQualityMode no string PossibleRecordQualityModes no string NumberOfTracks no ui4 0 2000 1 CurrentTrack no ui4 0 2000 1 CurrentTrackDuration no string CurrentMediaDuration no string CurrentTrackMetaData no string CurrentTrackURI no string AVTransportURI no string AVTransportURIMetaData no string NextAVTransportURI no string NextAVTransportURIMetaData no string RelativeTimePosition no string AbsoluteTimePosition no string RelativeCounterPosition no i4 AbsoluteCounterPosition no i4 CurrentTransportActions no string LastChange yes string A_ARG_TYPE_SeekMode no string ABS_TIME REL_TIME A_ARG_TYPE_SeekTarget no string A_ARG_TYPE_InstanceID no ui4 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActionsCurrent device RootDevice description:
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 Volumio-UPnP/AV JF Light Industries https://framagit.org/medoc92 UPnP front-end to MPD UpMPD 42 https://framagit.org/medoc92/upmpdcli/code/ upmpdcli version 1.5.8 libupnpp 0.20.2 image/png 64 64 32 /uuid-548a2cb5-2925-37ea-1818-dca6322e5686/icon.png /uuid-548a2cb5-2925-37ea-1818-dca6322e5686/presentation.html uuid:548a2cb5-2925-37ea-1818-dca6322e5686 urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /uuid-548a2cb5-2925-37ea-1818-dca6322e5686/urn-schemas-upnp-org-service-AVTransport-1.xml /uuid-548a2cb5-2925-37ea-1818-dca6322e5686/ctl-urn-schemas-upnp-org-service-AVTransport-1 /uuid-548a2cb5-2925-37ea-1818-dca6322e5686/evt-urn-schemas-upnp-org-service-AVTransport-1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /uuid-548a2cb5-2925-37ea-1818-dca6322e5686/urn-schemas-upnp-org-service-RenderingControl-1.xml /uuid-548a2cb5-2925-37ea-1818-dca6322e5686/ctl-urn-schemas-upnp-org-service-RenderingControl-1 /uuid-548a2cb5-2925-37ea-1818-dca6322e5686/evt-urn-schemas-upnp-org-service-RenderingControl-1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /uuid-548a2cb5-2925-37ea-1818-dca6322e5686/urn-schemas-upnp-org-service-ConnectionManager-1.xml /uuid-548a2cb5-2925-37ea-1818-dca6322e5686/ctl-urn-schemas-upnp-org-service-ConnectionManager-1 /uuid-548a2cb5-2925-37ea-1818-dca6322e5686/evt-urn-schemas-upnp-org-service-ConnectionManager-1UPnP devices found : 1
Device #0: ID 0x0 Volumio-UPnP/AV UID: uuid:548a2cb5-2925-37ea-1818-dca6322e5686 Location: http://192.168.0.120:49152/uuid-548a2cb5-2925-37ea-1818-dca6322e5686/description.xml
Max. memory for audio buffers: 62464MB
Local devices found : 5
Device #0: ID 0x90 Volumio Manufacturer: Apple, Inc. Model UID: 04:25:5C:B4:11:F0-2490763507166-airplay UID: 04:25:5C:B4:11:F0-2490763507166-airplay
Device #1: ID 0x63 Marathon Manufacturer: Apple Inc. Model UID: 0 0 UID: 38-B1-9E-FF-73-C2:output
Device #2: ID 0x41 Studio Display Speakers Manufacturer: Apple Inc. Model UID: Studio Display Audio Control:05AC:1114 UID: AppleUSBAudioEngine:Apple Inc.:Studio Display:00008030-001324843601802E:8,9
Device #3: ID 0x5d Altoparlanti Mac Studio Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
Device #4: ID 0x37 Microsoft Teams Audio Manufacturer: Microsoft Corp. Model UID: MSLoopbackDriverDevice_ModelUID UID: MSLoopbackDriverDevice_UID
