Which plugin do you use for which purpose? Hyperlink would be nice.
Thanks Kempy, which plugin do you use in A+?
This option is implemented for a reason I think. I only wonder for what reason
Room correction, headphone equalisation can be done this way. Does this fit your question?
That makes sense. Didn’t find any volume control plugins (replay gain e.d.). Most plugins are for music production.
OK, found this: http://www.rarewares.org/others.php#wavegain Didn’t try it yet. It’s old and doesn’t look plug and play to me.
I’m not using any VST plugin in A+ as I don’t have any need to use one.
I only tested some pro VST plugins in A+ because I’m in the test ring.
G.
