VST Plugin
I probably could have, but I asked it could generate such files and this worked out fine.
@Ddude003
This may be a solution for your plug-in I/O stack(s) (If it works in Audirvāna)…
and this multi-band processing approach is an intriguing tool…
Lol… I already have a solution… Used to work well in the previous version of Audirvana, works well in the Hang Loose Host for any Mac centric audio like Apple Music, and works well in Reaper… This is an issue with Audirvana plugin host not handling .cfg path/files correctly…
LOL … That’s tuff for you and your .cfg file/room correction strategy… Good luck with that… We’ll see what is real, in time… In the meantime don’t burn bridges…
Telling the truth is burning bridges? Wow… :roll_eyes:
LOL… that’s what you believe to be the impetus of my statement? Best to bark up a different log… Stay on course, you will for sure get what you deserve…
So what do you think I deserve @Agoldnear…
