Audi100
September 4, 2022, 9:41am
1
Hello!
After every start-up of Audirvana (Version 3.5.51, Win 10), the window’s screen position of a VST3 plug-in I’m using, has changed. This regularly sooner or later leads to an extent, that the plug-in window can no longer be seen at all.
How to »pin« that plug-in window?
Antoine
September 5, 2022, 8:11am
2
Hello @Audi100 ,
Which VST3 plugin are you using?
Antoine
September 6, 2022, 1:26pm
4
Unfortunately this is a Windows 10/11 bug that is happening from time to time on a numerous number of apps which has not been fixed for the moment.
In theory, you should never lose an open window off the edge of your screen. It should go so far and then offer to go full screen, but it should not disappear altogether. However, this is Windows, and strange things
Audi100
September 6, 2022, 5:33pm
5
In a way, that every Audirvana 3.5 user under Win 10/11 who uses VST3 window based plug-ins will experience this from time to time? Quite amazing …
Antoine
September 7, 2022, 7:20am
6
Any Windows user in general, not only by using Audirvāna. I have this issue from time to time when I use Visual Studio, even if it’s a Microsoft App
Audi100
September 7, 2022, 7:39am
7
Well – I see this kind of issue only with Audirvana and VST3.
And it would come to me as a surprise if I should be the first and only one to complain about it here.
system
Closed
December 6, 2022, 7:40am
8
