Although VST3 plugins are working well, Im unable to adjust in realtime as UI not displaying from toolbar. Therefore to adjust setting I have to stop playback and amend
Did you activate the setting ‘Realtime control (not for DSD playback)’? On my machine it is grayed out because I have no VSTs installed, but in your case this option should be active if you have activated ‘Use VST effects’,
See the screenshot below for the settings:
Thank you for quick response
Issue resolved by reinstalling Audirvāna
I have recently upgraded Windows which may have caused the problem
