VST3 REALTIME CONTROL - crash
Audirvana Studio 1.7.2 (10702)
Windows 10 (19044) with 32GB physical RAM
UAD Apollo twin
when I activate the VST3 function + REALTIME CONTROL , a minidump is generated
It is therefore impossible to use my plugins to check my own mix to make some adjustment
example with SoundID reference VST3 from beta 2.0 (41) (but same with others)
Thank you for your help
Tomorrow support from Audirvana will be present again. You could post the Debug info here. And send the dump to [email protected]. It seems quite a specific question, but Antoine will probably find it interesting.
I wish I could help you, but I don’t have Windows and I don’t have the plugins you have.
oh ok ! - thank you Jacob
note : it works perfectly when realtime control is OFF
Connected account:
	VST3 plugin #0: C:\Program Files\Common Files\VST3\SoundID Reference VST3 Plugin.vst3
		ClassID: 5653545053546A736F756E6469642072
	VST3 plugin #1: None
	VST3 plugin #2: None
	VST3 plugin #3: None
Bandwidth at 0dB = 89.7115%
Phase = 50%
Replay Gain: by album
AUTO: B:\MUSIQUE FLAC
Library database path: C:\Users\oleop\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 192.168.0.3 on port 54788
Qobuz: Connected as
Max. memory for audio buffers: 11804MB
Local Audio Engine: ASIO ASIO 2 driver version 1106
Universal Audio USB
Model UID:Universal Audio USB
Device: 6ch 32bits Integer, 24 bytes per frame 192kHz
Active Sample Rate: 192kHz
Universal Audio USB
Manufacturer:
Model Name: Universal Audio USB
Model UID: Universal Audio USB
Multichannel: 6 channels
Channel bitmap: Ox3f, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Number of channels: 6
Simple stereo device: No
6 ch Integer PCM 32bit little endian 44.1kHz
6 ch Integer PCM 32bit little endian 48kHz
6 ch Integer PCM 32bit little endian 88.2kHz
6 ch Integer PCM 32bit little endian 96kHz
6 ch Integer PCM 32bit little endian 176.4kHz
6 ch Integer PCM 32bit little endian 192kHz
Local devices found : 5
Device #0: ASIO Avid Driver Manufacturer: Model UID: ASIO Avid Driver UID: ASIO Avid Driver Model Name: ASIO Avid Driver
Device #1: Generic Low Latency ASIO Driver Manufacturer: Model UID: Generic Low Latency ASIO Driver UID: Generic Low Latency ASIO Driver Model Name: Generic Low Latency ASIO Driver
Device #2: Universal Audio Apollo FireWire Manufacturer: Model UID: Universal Audio Apollo FireWire UID: Universal Audio Apollo FireWire Model Name: Universal Audio Apollo FireWire
Device #3: Universal Audio Thunderbolt Manufacturer: Model UID: Universal Audio Thunderbolt UID: Universal Audio Thunderbolt Model Name: Universal Audio Thunderbolt
Device #4: Universal Audio USB Manufacturer: Model UID: Universal Audio USB UID: Universal Audio USB Model Name: Universal Audio USB
If you deactivate upsampling. Does that make a difference?
And the buffer reduced to 4 GB?
Is the WASAPI an option instead of ASIO?
the upsampling is giving the sauce i guess :slight_smile:
it seems to be one of the main problem but when I deactivated it, no dump but it creates a huge glitch on my monitors - so scared…
Then jafter restart with this setting on the left monitor good, but on the the right one annoying glitches
I reduce the buffer by the way I think I don’t need so much, thank you.
I’m in Asio because on Win 10 with an UAD Asio soundcard. way better than Wasapi
I’m composer and this is in my Home studio where I’m listening music (acoustic treatment room)
I send a message to Antoine with a link to the dump file.
Thanx again for your time and support
Hello @oleoproteus,
can you send your audirvana.log and audirvana.dmp file at [email protected]?
to show AppData folder:
https://support.microsoft.com/en-us/windows/view-hidden-files-and-folders-in-windows-10-97fbc472-c603-9d90-91d0-1166d1d9f4b5
Thanx
email sent
I have this same issue with Amanero ASIO drivers in real-time modes for Windows 10. I am using the Fabfilter Pro-Q3 VST3 plugin.
@WillieB Are you using 1.8.1 Audirvāna? Let’s get all your info to [email protected]
actually I solve the problem using Wasapi mode
The new version is not solving this, still get the dump
