Hi all
I use the VST3 SonEQ in Audirvana direct from my PC to a B&W Zeppelin connected with USB, it works!
BUT if I select in Audirvana a connection to my microRendu via ethernet, the VST3 dont work, is this normal?
BR Jorgen
Hi all
BR Jorgen
Hello Jorgen, you can’t change your plugin settings while listening you mean?
I think I have no acces to the plugin at all!
It sure does, but when I do a setting, I am asked to save which I do, but nothing happens to the sound.
Really strange, i just tried on my side with a microRendu and the plugin worked for me. Have you tried to set the plugin on maximum or minimum on each button to try to ear the difference?
I just tried the highpass on 350hz
Jorgen you have to put the realtime control button to off.
Correct the equalizer before to play and try.
Bye
When I open the settings for Audirvana I don’t even see the section for VST plugins. I justy installed sonEQ freeware and it doesn’t show up anywhere in my settings. Why is this
It is not in the general settings of Audirvana, but in the sound card settings of Audirvana. Click on the sound card Icon (lower right) and in those settings you can see the section for VST plugins.
