How can I enable WASAPI exclusive mode in Windows 10?, thanks.
Hello @joser9616,
Are you talking about this setting in Windows 10?
Ok, yes, thatās it; I was reading this in the page:
āThe implementation differs according to the OS: With Mac, it is necessary to impose an integer mode calculation (as opposed to floating) to neutralize the mixer. With Windows, the format remains consistent when the WASAPI driver has exclusive access.ā
I donāt know if with the ASIO drivers itās the same thing, thanks.
This setting is by default enabled in Windows 10. You need to activate if itās not the case since you will not have audio from WASAPI or ASIO either way.
