Hello,
Does anybody know whether the Waves Q10 Paragraphic EQ plugin works with Audirvana on Windows 10?
Thanks,
Andrea
Hello,
Thanks,
Andrea
To answer my own question: Yes, it does. (In case anybody else were wondering and ran into this thread.)
I just got this plug-in, myself, and I was wondering whether you found any presets or settings particularly useful, just to sweeten the sound in general. I am trying to take the edge off and get AV to sound a little more like Amarra, honestly. But I am not especially good with EQ.
Hi Aledbaran,
Iām using oratory1990ās preset to EQ my Focal Elegia to the Harman Target Curve.
Unfortunately Iām unacquainted with Amarra, and Iām not particularly well-versed in EQ myself, so I couldnāt advise you on how to achieve your stated end goal. Iāve stopped worrying about EQ the moment I read about the Harman Target Curve and found oratory1990ās subreddit with the presets for various headphones. You may find it here: https://www.reddit.com/r/oratory1990/
Alternatively, the AutoEQ project has even more presets, some of which are based on oratory1990ās work: https://github.com/jaakkopasanen/AutoEq
Hope this helps.
Kind regards,
Andrea
Thanks very much for your reply and suggestions, Andrea. Iāll look into what you mention. Actually, one other thing about Amarra that I like is that it comes with a great preset for my Etymotic earphones. But the interface is just a disaster.
Actually, everything there that you linked to looks way over my head. I canāt even figure out how to edit the parameters of the Wave Q10 plug-in in Audirvana. In the āconfigureā option, it allows me to choose factory presets, but there is no way that I can find that allows me to customize the plug-inās parameters directly.
I know, I probably have no business getting into the realm of audiophila with such limited technical knowledge, but what can I say? [laughs]. Anyway, thank you again.
Thatās strange, as when I open the plugin in Audirvana Iām right where it lets me customize itā¦! Dialing the settings in is pretty simple. Could you locate your earphones in oratory1990ās list? If you have the values handy, we can create the preset in Q10.
Thanks for your reply. It is strange. When I click āconfigureā, the plug-in appears at the bottom left-hand corner of the screen, about quarter-size, in a red box. When I click around in the plug-in window, some parameters light up, but I canāt move the knobs with my mouse. So, I am not sure I will even be Abe to edit it.
But anyway, my earphones are the Etymotic ER-4X Pro. Oratory1990 has the ER-4XR, which is the closest thing. I am uploading a screen cap of the values.
So, the settings you need are at the bottom of the PDF you took a screenshot from.
The Q10 plugin has several items to choose from in Audirvanaās āEffect plug-in #1ā drop-down menu. The one you want is called āFx|EQ - Waves Q10 Stereoā and it looks like this:
You can use the āINPUTā slider to set the āpreampā value from oratory1990ās file. You then need to activate the first 8 bands by clicking on the āpowerā button next to each, and either use the knobs to dial in the values, or double-click and type the value in (which I found to be the quicker, more precise way to do it.)
The resulting curve should look approximately like the āEQ curve totalā graph in oratory1990ās PDF.
Thank you very, very much! I shall give it a try in a little while and will let you know how it goes.
I simply canāt create the presets in Audirvana. It wonāt let me edit the parameters reliably. Some buttons and knobs respond randomly where I click, and others donāt respond, at all.
So, I created the Q10 preset in GarageBand and saved it. Now, the problem is that Audirvana will not show user presets in my āconfigureā options. It shows only the same old factory presets.
So, I am about to give up. It appears that I will have to choose between Audirvanaās inferior (to me, subjectively) sound, but better interface, or Amarraās better (to me, subjectively) sound, but worthless interface (Catalina broke the iTunes/Music compatibility mode, and God only knows when Sonic Studios will get around to reinstating it). But I do want to say, sincerely, many thanks again for your help.
The Q10 knobs can be finicky, especially the Q one, but you should be able to click the field that shows the number and just enter the number you want manually.
As for using your custom configuration in Audirvana, when you click Load and the drop-down menu opens, you should see āOpen Preset Fileā as the first item, above the factory presets. That should let you pick the file you created in GarageBand, provided that the file format is compatible with the plugin (not sure what file format it uses; I created my preset from within Audirvana.)
Unfortunately, my Audirvana has no such option to open presets files. My only under options under Audio Units are āconfigureā, then the box opens, āpresetsā, then, after clicking presets, the factor presets for the Q10. And when I click the values fields to try to type something into them, they are completely unresponsive. Itās very odd.
Your UI looks a bit differentāguess thatās to be expected between Windows and MacOS, but I donāt have that huge red background at all. Anyhow, letās focus exclusively on the bottom-left corner, where the EQ interface is, and pretend everything else (the red stuff and the āpresetsā stuff) doesnāt exist. The top-right corner of the EQ interface has a āLoadā button that should enable you to pick the preset you created in GarageBand. In my interface, thatās also where I need to click if I want one of the existing presets, so itās possible theyāll be there too.
The fields with the numbers should become editable on a double-click. If they arenāt, I would consider touching base with Wavesā support (they answered me pretty quickly when I needed them.)
Thank you again. The āloadā button does not work. I click all day and nothing happens. The same with everything at the top of the screen.I think that you are right; itās time to request technical support!
Most definitely!
Let me know how it goes
