UPNP:
Detection:
PCM supported sample rate : 44.1 - 48 - 88,2 - 96 - 175,4 - 192 - 354 - 384
DSD supported sample rate : 64 - 128
DSD Over PCM setting : None
MQA capability : No
Volume:
Volume can be changed : Yes
Device can mute - unmute: Yes
There is currently an issue affecting the value displayed in Audirvāna for this device, Weiss is aware of this and is working on it.
Playback:
Best upsampling setting for device : None
Setting do not send RAW PCM activated : No
Playback Control:
Gapless playbak option enabled : No
USB:
Detection:
(Windows only) best option to play to the device : WASAPI
DSD Over PCM setting : DoP 1.0
MQA capability : No
Playback:
Antoine
Split this topic
December 12, 2024, 10:36am
2
2 posts were merged into an existing topic: Weiss DAC 204
With the new update audirvana does not detect the weiss upnp, it detects it in usb only, the “local” button does not respond and it is grey.
I have unistalled the audirvana e reinstalled twice, the firewall permission are given.
please advise
Marco
Jud
May 8, 2026, 3:00am
5
Could the new update have some difference (a different UPnP port, for example) that keeps it from getting through the firewall?
Good question , I have turned the firewall off to see if that made a difference, but no luck
I have contacted Wiss they are looking into the problem
Weiss firmaware Version 2.8.2 was released, I have installed it and it fixes the problem, now upnp on audirvana finds the dac again, but in order to do that I had to reinstall the audirvana 3.1.0
