I can’t seem to get a straight answer here. I’m currently using Audirvana to stream Tidal tracks from my 2019 Macbook pro to my Naim Atom. I’m using WiFi but am thinking it might be better to direct cable but can’t figure out what is the best connection.
Best to use the headphone jack to the DAC’s Toslink w/ the appropriate cable?? If so what ‘quality’ cable should i buy, or is the seven dollar Amazon cable okay to use??
