Each new version of a software brings new features, but can also have issues.
Studio has more features than Audirvana Plus. Itās a fact. But there were issues with it. They are fixed and will disappear over time. Itās like that with all the applications.
Yes⦠These things Iāve learned to be patient around and temper my expectations⦠the result of having been on the bleeding-edge of these technologies as they have evolved and continue to evolve⦠I know what works and what may be riddled with frustrations⦠For me it is simple nowā¦
So you didnāt received any Newsletter since last May? Spoiler alert, you received all of them but I can see they have not been opened for those we made back in September, November and December
Yes AudirvÄna Studio still have issues we need to fix but those things takes time as I need to keep saying this over and over again. Have you seen the release note of the last update? it is really long and we will not stop doing updates like this to fix the issues of AudirvÄna Studio. We canāt do everything at the same time, we are not robots and we need to decide which issue is more important than the other.
Oh and by the way, donāt miss sharing your setup since itās the topic of this thread
I must be getting them in spam folder, can you please send one so I can see where it lands? Since I got you could you please reset my 3.5 license, no big hurry I would like to test on M1 MacBook Pro
Itās a new protocol.
There are two Linux distributions that I know, and there are a few Japanese devices that use it.
But itās very good, and over time it will spread for sure to more and more devices.
A player can stream with its existing upnp protocol or with Diretta. Itās not necessary to remove upnp from the player. It can keep its upnp compatibility. Diretta becomes an additional streaming option. More solid and with a better sound quality.
Removing upnp would be absurd, because it will cut the compatibility of Studio with 99% of the streamers. Adding Diretta will offer to Studio a clear qualitative advantage if Studio is coupled to a Darietta capable streamer.
My setup still does not work with AS. It never has, and I have less than a week of trial time left:
Music on external drive-> 2018 Mac Mini six-core, 64gb RAM (still the top-of-the-line model)-> Audirvana (no upsampling, effects, EQ, or filters-> 10gb Ethernet port on Mac Mini-> cat 6 Ethernet cable-> Motorola MG8702 modem-> cat 6 Ethernet cable-> MicroRendu-> Pangea Premier XL USB cable-> Schiit Yggdrasil.
I still canāt play a single song. With my setup, this is a music player that doesnāt play music.
Before adding additional protocols, perhaps Audirvana might consider getting UPnP to work reliably? Iāve been using Minimserver/BubbleUPnP/Linn Kazoo pretty much all week with zero crashes or lock-ups. Yes, I know Studio isnāt server-based, but could this be an option in the future? It seems that UPnP software is far more stable when pushing tracks to the renderer, as opposed to the renderer pulling tracks from the software.
Also, honest question, but how many manufacturers implement Diretta as a protocol within their products?
Few at the moment, because it is a new protocol. But it will be adopted by many for sure, because it is so much better than all the existing protocols.
So unless a firmware update becomes available enabling this new protocol (and Iām reasonably certain that the manufacturer of my streamer, Cyrus, wouldnāt release one for my model), then quite a few of us currently having problems would need to purchase new equipment to make use of it.
Studio is marketed as UPnP software, yet doesnāt appear to have the stability of others (which coincidentally are free), yet charge for the privelege of constant crashes and lock-ups.
I agree with you that should Diretta prove more stable then of course Audirvana should take the opportunity to implement it. Itās just that Iād like to see the existing UPnP protocol work as expected.
Well, serious sound improvement⦠I am just trying out Diretta within GentooPlayer. It sounds good, no doubt, clean and neutral. But whether itās so much better than other protocols, is questionable.
Some time ago, there was all the rage over at Roon with the new VitOS. Because it uses far less resources than others, etc, etc⦠it sounds so much better. Today, no one speaks about VitOS anymore (at least on the forum).
As far as I know, AS installed on a Windows system works with Diretta, but it doesnāt work with Mac OS. Too bad!!!
Itās good when Audirvana is looking into Diretta, but many users would be first and foremost interested in having those pesky UPnP problems solved.
