i can’t find my personal Tidal playlist anymore… the one under Tidal is the recommended one, not my own.
Can’t find it either. Without my own playlists Studio is pretty useless.
Open the playlist manager, it’s probably there.
Thank you. I found it. It can be imported to My Music from the playlist manager. Ok, you have to do that manually but in contrary to the Tidal app, you can sort your playlists which is a good thing.
