So I set the EQ. But where are the eq settings saved? In the cloud? Locally? As I saw are not reflected in the debug info. Need this for backup purpose (reinstall of AS/OS). Thanks! Btw, great job!
Hi @DGrigorescu,
For the moment, it’s local only and stored in the Audirvāna Studio database file on your computer.
Thank you! It’s ok since I backup my db regulary. Have a great weekend!
Hello as I do not get it, I create and save 2 presets for my two headphones to m second pc that I use Audirvana.Will the presets be available to my other pc and my Android app? Thanks
Hi @Entos1 , we have not made any change in that regard, the presets are still local
Hello @Antoine thanks for the response.
So what is going on with my question? Are the presets saved to every device or need to be added again manual? Or can be exported and then imported again to other device?
That is I want to find out.
Thanks in advance!
Each preset is stored on the device you set it up on. They can’t be exported, so you will need to do it on your own on a second device until we have an export/import option for the preset.
