White noise @ 192 khz
Hi,
I don’t seems to be able to play files (Tidal) @ 192khz. I’m always getting a white noise. Now, there are so many setting that honestly, after trying any combination of settings, the best I was about to get is 24b/88khz by disabling upsampling.
I’m using the M2Tech HiFace, and my DAC is rather old, but supports 24b/192. I use to be OK with the older Audirvana version so I know it works.
After trying all sort of things for 3 hrs, I’d take any suggestions at this point.
Cheers!
Den
click that menu and come back and paste the result here
Hi, here is the log file:
Audirvana Studio 2.4.0 (20400)
macOS 12.6.9 with 8GB physical RAM
Connected account of : [ME]
Bandwidth at 0dB = 99.5%
Phase = 66%
AUTO: /Users/[me]/Documents
Library database path: /Users/[me]/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 20
Listening on 127.0.0.1 on port 49153
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
M2Tech hiFaceTWO UAC2 Output
Model UID:hiFaceTWO UAC2:249C:930B
UID:AppleUSBAudioEngine:M2Tech:hiFaceTWO UAC2:14100000:1
Limit bitdepth to 24bit: ON
Selected device:hiFaceTWO UAC2 Output
Manufacturer: M2Tech
Model name: M2Tech hiFaceTWO UAC2 Output
Model UID: hiFaceTWO UAC2:249C:930B
UID: AppleUSBAudioEngine:M2Tech:hiFaceTWO UAC2:14100000:1
USB Vendor ID: 0x249c
USB Product ID: 0x930b
ID 0x2a
Stream ID 0x2b 2 channels starting at 1
18 virtual formats:
24 physical formats
Local devices found : 3
Device #0: ID 0x34 Built-in Output
Model UID: AppleHDA:108
Device #1: ID 0x4a HDMI
UID: AppleHDAEngineOutputDP:3,0,1,1:0:{2D4C-0505-00000000}
Model name: Apple Inc. HDMI
Device #2: ID 0x2a hiFaceTWO UAC2 Output
Chromecast devices found : 1
Device #0: BRAVIA 4K GB ATV3
Model name: BRAVIA 4K GB ATV3
(bump)
Just checking if anyone has any suggestions.
Cheers!
Den
You might try lowering your playback pre-load memory allocation to 2GB as you are using more that 50% of your system RAM for playback pre-load memory.
Try rebooting your system and make sure your DAC is selected as the output device in Audio MIDI Setup…
Hi, it doesn’t seem to make any difference.
Thanks for the suggestion.
try to turn the 2 of them OFF ?
Contact M2 Tech…
