Longtime Audirvana user, first time poster (and my first playback issue).
I recently updated to Studio 2.3.4 and have been unable to find the right configuration to play DSD files (both DSF and SACD ISOs). I had to tweak settings for WAV and Tidal, but i finally sorted that out.
I have tried adjusting the following parameters:
Different buffer sizes (low end of 9GB to high end of 23GB)
Different DoP Settings
Updating MacOS
Different USB DACs
Integer Mode (off/on)
Large CoreAudio I/O buffer (off/on)
Issues persist with two different DACs (Chord Mojo + PS Audio Sprout100). Debug file below is from Sprout100:
Audirvana Studio 2.3.4 (20304)
macOS Version 13.5 (Build 22G74) with 32GB physical RAM
Connected account of : Jordan Kenning
Sync list: 3 folders
AUTO: /Users/kenning/Library/CloudStorage/Dropbox/Music/Acoustic Sounds Super HiRez
AUTO: /Users/kenning/Library/CloudStorage/Dropbox/Music/DVD-As
AUTO: /Users/kenning/Library/CloudStorage/Dropbox/Music/SACD ISOs
Library database path: /Users/kenning/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 721
Listening on 127.0.0.1 on port 49168
Max. memory for audio buffers: 10096MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: OFF
Actual I/O buffer frame size: 4096
PS Audio PS Audio USB Audio 2.0
Model UID:PS Audio USB Audio 2.0:2616:0113
UID:AppleUSBAudioEngine:PS Audio :PS Audio USB Audio 2.0:100000:1
Hog Mode is on
Sample rate switching latency: 0.5s
Selected device:PS Audio USB Audio 2.0
Manufacturer: PS Audio
Model name: PS Audio USB Audio 2.0
Model UID: PS Audio USB Audio 2.0:2616:0113
UID: AppleUSBAudioEngine:PS Audio :PS Audio USB Audio 2.0:100000:1
USB Vendor ID: 0x2616
USB Product ID: 0x0113
ID 0x5b
Audio buffer frame size : 53 to 4096 frames
Max volume alert: Disabled
Stream ID 0x5c 2 channels starting at 1
24 virtual formats:
32 physical formats
Local devices found : 3
Device #0: ID 0x5b PS Audio USB Audio 2.0
Device #1: ID 0x4f MacBook Pro Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Device #2: ID 0x32 Microsoft Teams Audio
Manufacturer: Microsoft Corp.
Max. memory for audio buffers: 6GB max or less than 6GB to find the sweet-spot.
Local Audio Engine: CoreAudio Integer mode: “ON” Use max I/O buffer size: “ON”
Try setting Limit bit depth to 24bit: “ON” … (It appears from the PS Audio specifications, that Sprout only supports 24 bit PCM in Integer)
Don’t enable the Volume Control
If you are trying to play DSD256 files, no can do… The maximum DoP 1.1 PCM carrier sample-rate the Sprout will support is 352.8kHz, (USB only)
If you are trying to play DSD256 files, no can do … The maximum DoP 1.1 PCM carrier sample-rate the Sprout will support is 352.8kHz, (USB only)
Should be good there – all my DSFs/ISOs are DSD64.
Unfortunately the issue persists on both Sprout100 and Mojo; one of these changed settings is also causing white noise issues with TIDAL.
I tried several buffer sizes… moving downward from 6GB to 2GB in 1GB increments.
Another debug dump below in case others have thoughts/suggestions…
Tracks with no MBID: 777
Listening on 127.0.0.1 on port 50754
Max. memory for audio buffers: 4936MB
Integer mode: ON
Active Sample Rate: 176.4kHz
Selected device:Mojo
Manufacturer: Chord Electronics Ltd
Model name: Chord Electronics Ltd Mojo
Model UID: Mojo:245F:0815
UID: AppleUSBAudioEngine:Chord Electronics Ltd:Mojo:413-001:2
USB Vendor ID: 0x245f
USB Product ID: 0x0815
ID 0x75
11 available sample rates up to 768000Hz
32000
Stream ID 0x76 2 channels starting at 1
22 virtual formats:
22 physical formats
Device #0: ID 0x75 Mojo
Model UID: Speaker
Did this ever play DSDxxx without noise?
Do you have a Local storage device that you can connect via USB and play DSD files?
Are you using a USB hub?
Are you wired to your router or using WiFi?
Try to drop two or three cd from dropbox cloud storage to a folder named ´test’ on your desktop, and add that folder to audirvana, and see if it still s*ck
Yes. Issues didn’t start until the Studio 2.3.4 upgrade.
Technically all these files are local; they just live in a folder that syncs with the cloud for backup purposes. However, I have tried copying DSFs/ISOs to a new desktop folder (per @RunHomeSlow’s suggestion) and still get the same issue.
I have also tried to play files via an external USB drive per your suggestion above. Same white noise issues.
No. I have also tried different USB cables between the laptop & DAC. Issues persist.
The only variables in my setup over the past year have been upgrades to Audirvana software and MacOS. Honestly I’m surprised that I’m the only one experiencing these issues…
Me again… been on the road for work a lot lately, and this issue got put on the back burner.
Still having issues following a fresh install.
I’m not sure how to answer that. It’s white noise (digital static) at the forefront with the music barely audible in the background.
Not a recent installation; it is part of the Microsoft Office apps I use for work. Prior to my current issues, I was able to successfully play DSD files even with Teams installed.
MacBook Pro 14" 2021/MacOS Ventura 13.5
I’m kind of surprised at how little conversation there seems to be about an issue like this on the forum; it’s hard to believe I’m the only one with these challenges.
I should have mentioned that my fresh install is of 2.4.0 (which replaced my initial version of 2.3.4:
Audirvana Studio 2.4.0 (20400)
Fingerprinting track 219/919 : /Users/kenning/Library/CloudStorage/Dropbox/Music/SACD ISOs/Beck - Sea Change.iso
Listening on 127.0.0.1 on port 49610
Max. memory for audio buffers: 8090MB
Integer mode: ON
Model UID:Mojo:245F:0815
UID:AppleUSBAudioEngine:Chord Electronics Ltd:Mojo:413-001:2
ID 0x32
32000
Stream ID 0x33 2 channels starting at 1
22 virtual formats:
22 physical formats
Device #0: ID 0x32 Mojo
Device #1: ID 0x59 MacBook Pro Speakers
Model UID: Speaker
Device #2: ID 0x3c Microsoft Teams Audio
Just for information, I have used the original Chord Mojo, Mojo 2 and Hugo 2 with AS since its release. I routinely play purchased/downloaded DSD files from NativeDSD using DOP 1,1 and have never had an issue with background noise even though I always install the latest updates of the OS and Audirvana
A few differences in my setup, I never install the Teams Audio Driver, Teams works for conferencing fine without it being installed. Otherwise your system settings for a mojo are the same as mine.
The original cables that came with Mojo are Micro USB to USB A are you using a dongle to connect to your 14" MB Pro or did you purchase seperate Micro USB to USB-C cables (I use the latter). Could be a dongle issue if you are using one?
As the noise issue is applicable to two different DAC’s then its not a device issue. As a last resort, if all else fails, I would reinstall macOS from scratch with a clean install. Then copy across your music files and install Audirvana first. Try again. If OK then install your additional software and see if the problem re-occurs to ascertain if it is a software conflict.
