Hi,
I’m getting white noise on random tracks with Tidal trough Audirvana via upnp with Allo Digione Signature Player (GentooPlayer) connected through spdif to a Naim nDAC. When I get the white noise (usually 1 track on 10, MQA) if a restart the track the problem disappear until a next problematic track. The problem is random and I did not find a common pattern but is very annoying as can damage my speakers. Here my debug info:
macOS 10.15.7 with 8192MB RAM
Registered to *****
Per track: OFF
Max allowed volume: 0
Sync list: 0 folders
Library database path: /Users/*************/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: GentooPlayer-UPNP Model UID:JF Light Industries GentooPlayer-UPNP UID:uuid:af03ea94-7c61-3194-5ddc-dca6322df8fa
UPnP device at http://192.168.2.234:49152/uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/description.xml
ID 0x0 GentooPlayer-UPNP Manufacturer:JF Light Industries
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::application/flac:*
http-get::application/x-flac:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/aif:
http-get::audio/aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/matroska:
http-get::audio/x-matroska:
http-get::audio/mp1:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-ape:
http-get::audio/ape:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::audio/x-wavpack:
http-get::video/mp4:
DLNA 1.5: No
Gapless playback: Yes
Can play native DSD: Yes
14 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 00:00:00
CurrentURI:
CurrentURIMetadata:
nextURI: http://192.168.2.112:49152/audirvana/audio_0_248.wav
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 TransportState no string STOPPED PLAYING TransportStatus no string OK ERROR_OCCURRED PlaybackStorageMedium no string PossiblePlaybackStorageMedia no string RecordStorageMedium no string PossibleRecordStorageMedia no string CurrentPlayMode no string NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL RANDOM DIRECT_1 NORMAL TransportPlaySpeed no string 1 no RecordMediumWriteStatus string CurrentRecordQualityMode no string PossibleRecordQualityModes no string NumberOfTracks no ui4 0 2000 1 CurrentTrack no ui4 0 2000 1 CurrentTrackDuration no string CurrentMediaDuration no string CurrentTrackMetaData no string CurrentTrackURI no string AVTransportURI no string AVTransportURIMetaData no string NextAVTransportURI no string NextAVTransportURIMetaData no string RelativeTimePosition no string AbsoluteTimePosition no string RelativeCounterPosition no i4 AbsoluteCounterPosition no i4 CurrentTransportActions no string LastChange yes string A_ARG_TYPE_SeekMode no string ABS_TIME REL_TIME A_ARG_TYPE_SeekTarget no string A_ARG_TYPE_InstanceID no ui4 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActionsCurrent device RootDevice description:
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 GentooPlayer-UPNP JF Light Industries https://opensourceprojects.eu/u/medoc/profile/ UPnP front-end to MPD UpMPD 1.0 https://opensourceprojects.eu/p/upmpdcli/code/ 42 /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/presentation.html uuid:af03ea94-7c61-3194-5ddc-dca6322df8fa urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/urn-schemas-upnp-org-service-AVTransport-1.xml /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/ctl-urn-schemas-upnp-org-service-AVTransport-1 /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/evt-urn-schemas-upnp-org-service-AVTransport-1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/urn-schemas-upnp-org-service-RenderingControl-1.xml /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/ctl-urn-schemas-upnp-org-service-RenderingControl-1 /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/evt-urn-schemas-upnp-org-service-RenderingControl-1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/urn-schemas-upnp-org-service-ConnectionManager-1.xml /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/ctl-urn-schemas-upnp-org-service-ConnectionManager-1 /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/evt-urn-schemas-upnp-org-service-ConnectionManager-1 urn:av-openhome-org:service:Info:1 urn:av-openhome-org:serviceId:Info /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/urn-av-openhome-org-service-Info-1.xml /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/ctl-urn-av-openhome-org-service-Info-1 /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/evt-urn-av-openhome-org-service-Info-1 urn:av-openhome-org:service:Time:1 urn:av-openhome-org:serviceId:Time /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/urn-av-openhome-org-service-Time-1.xml /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/ctl-urn-av-openhome-org-service-Time-1 /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/evt-urn-av-openhome-org-service-Time-1 urn:av-openhome-org:service:Volume:1 urn:av-openhome-org:serviceId:Volume /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/urn-av-openhome-org-service-Volume-1.xml /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/ctl-urn-av-openhome-org-service-Volume-1 /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/evt-urn-av-openhome-org-service-Volume-1 urn:av-openhome-org:service:Credentials:1 urn:av-openhome-org:serviceId:Credentials /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/urn-av-openhome-org-service-Credentials-1.xml /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/ctl-urn-av-openhome-org-service-Credentials-1 /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/evt-urn-av-openhome-org-service-Credentials-1 urn:av-openhome-org:service:Playlist:1 urn:av-openhome-org:serviceId:Playlist /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/urn-av-openhome-org-service-Playlist-1.xml /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/ctl-urn-av-openhome-org-service-Playlist-1 /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/evt-urn-av-openhome-org-service-Playlist-1 urn:av-openhome-org:service:Radio:1 urn:av-openhome-org:serviceId:Radio /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/urn-av-openhome-org-service-Radio-1.xml /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/ctl-urn-av-openhome-org-service-Radio-1 /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/evt-urn-av-openhome-org-service-Radio-1 urn:av-openhome-org:service:Product:2 urn:av-openhome-org:serviceId:Product /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/urn-av-openhome-org-service-Product-2.xml /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/ctl-urn-av-openhome-org-service-Product-2 /uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/evt-urn-av-openhome-org-service-Product-2UPnP devices found : 3
Device #0: ID 0x0 GentooPlayer-UPNP UID: uuid:af03ea94-7c61-3194-5ddc-dca6322df8fa Location: http://192.168.2.234:49152/uuid-af03ea94-7c61-3194-5ddc-dca6322df8fa/description.xml
Device #1: ID 0x0 Denon AVR-X3200W UID: uuid:5f9ec1b3-ff59-19bb-8530-0005cd613161 Location: http://192.168.2.246:8080/description.xml
Device #2: ID 0x0 La mia stanza da letto UID: uuid:WIFIMusic-1_0-240A-64FE-D65C Location: http://192.168.2.123:49494/description.xml
Max. memory for audio buffers: 5982MB
Device #0: ID 0x4b Altoparlanti MacBook Pro Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
