Audirvana Studio 2.9.3 (20903)
macOS 13.6 x86_64 with 32GB physical RAM
Connected account of : kingfun home
Bandwidth at 0dB = 99.5%
Phase = 66%
AUTO: /Users/music
iTunes/Music library synchronization: last synchronized on Thu Oct 24 14:02:00 2024
Library database path: /Users/kingfunhome/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 3247
Listening on fe80::829:3353:189b:462d%en0 on port 49743
UI theme: light
Font size: regular
Language: 中文
我的音乐
无线电收发器
播客
流媒体
本地
Startup view: 我的音乐:专辑
Use Apple Remote: yes
Number of paired remotes: 6
Screen saver disabled: yes
Active method: UPnP
Preferred device: [UPnP] LUMIN T2:LUMIN Model UID:Pixel Magic Systems Ltd. T2 UID:uuid:4c494e4e-3d9b-11e1-b86c-0016e8030f74
Selected device:LUMIN T2:LUMIN
Manufacturer: Pixel Magic Systems Ltd.
Model name: T2
Model UID: Pixel Magic Systems Ltd. T2
UID: uuid:4c494e4e-3d9b-11e1-b86c-0016e8030f74
UPnP device at http://192.168.2.3:23000/
ID 0x0
Volume control: Yes
Max volume alert: Disabled
Raw DSD (msb)
UPnP set capabilities
Maximum PCM bitdepth set: 24
Maximum DSD rate set: DSD256
Avoid RAW PCM streams: Yes
http-get:::*
http-get::audio/mpeg:
http-get::audio/mpeg3:
http-get::audio/mp3:
http-get::audio/x-mp3:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/mp4:
http-get::audio/mpeg4-generic:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aac:
http-get::audio/alac:
http-get::audio/x-alac:
http-get::audio/dsd:
http-get::audio/x-dsf:
http-get::audio/x-dff:
http-get::application/octet-stream:
http-get::audio/opus:
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: dB (-90dB to 0dB)
15 virtual formats:
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 11289.6kHz finite length
0 physical formats
NrTracks: 2
MediaDuration: 00:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
Current transport actions:
Play,Pause,Stop,Seek,Next,Previous
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 LUMIN T2:LUMIN Pixel Magic Systems Ltd. https://www.luminmusic.com/ LUMIN T2 1.0 https://www.luminmusic.com/ uuid:4c494e4e-3d9b-11e1-b86c-0016e8030f74 QPlay:2 DMR-1.50 image/png 120 120 24 /images/lumin-120x120.png image/png 48 48 24 /images/lumin-48x48.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /AVTransport/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /AVTransport/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /ConnectionManager/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /ConnectionManager/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /RenderingControl/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /RenderingControl/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:av-openhome-org:service:Product:1 urn:av-openhome-org:serviceId:Product /Product/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /Product/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /Product/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:av-openhome-org:service:Playlist:1 urn:av-openhome-org:serviceId:Playlist /Playlist/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /Playlist/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /Playlist/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:av-openhome-org:service:Time:1 urn:av-openhome-org:serviceId:Time /Time/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /Time/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /Time/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:av-openhome-org:service:Info:1 urn:av-openhome-org:serviceId:Info /Info/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /Info/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /Info/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:av-openhome-org:service:Volume:1 urn:av-openhome-org:serviceId:Volume /Volume/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /Volume/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /Volume/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:av-openhome-org:service:Transport:1 urn:av-openhome-org:serviceId:Transport /Transport/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /Transport/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /Transport/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:magictv-com:service:MagicAudio:1 urn:magictv-com:serviceId:MagicAudio /MagicAudio/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /MagicAudio/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /MagicAudio/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:av-openhome-org:service:Credentials:1 urn:av-openhome-org:serviceId:Credentials /Credentials/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /Credentials/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /Credentials/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:av-openhome-org:service:Radio:1 urn:av-openhome-org:serviceId:Radio /Radio/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /Radio/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /Radio/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:av-openhome-org:service:Receiver:1 urn:av-openhome-org:serviceId:Receiver /Receiver/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /Receiver/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /Receiver/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:schemas-tencent-com:service:QPlay:2 urn:tencent-com:serviceId:QPlay /QPlay/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /QPlay/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /QPlay/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xmlCurrent device RootDevice description:
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 LUMIN T2:LUMIN Pixel Magic Systems Ltd. https://www.luminmusic.com/ LUMIN T2 1.0 https://www.luminmusic.com/ uuid:4c494e4e-3d9b-11e1-b86c-0016e8030f74 QPlay:2 DMR-1.50 image/png 120 120 24 /images/lumin-120x120.png image/png 48 48 24 /images/lumin-48x48.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /AVTransport/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /AVTransport/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /ConnectionManager/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /ConnectionManager/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /RenderingControl/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /RenderingControl/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:av-openhome-org:service:Product:1 urn:av-openhome-org:serviceId:Product /Product/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /Product/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /Product/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:av-openhome-org:service:Playlist:1 urn:av-openhome-org:serviceId:Playlist /Playlist/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /Playlist/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /Playlist/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:av-openhome-org:service:Time:1 urn:av-openhome-org:serviceId:Time /Time/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /Time/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /Time/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:av-openhome-org:service:Info:1 urn:av-openhome-org:serviceId:Info /Info/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /Info/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /Info/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:av-openhome-org:service:Volume:1 urn:av-openhome-org:serviceId:Volume /Volume/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /Volume/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /Volume/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:av-openhome-org:service:Transport:1 urn:av-openhome-org:serviceId:Transport /Transport/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /Transport/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /Transport/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:magictv-com:service:MagicAudio:1 urn:magictv-com:serviceId:MagicAudio /MagicAudio/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /MagicAudio/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /MagicAudio/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:av-openhome-org:service:Credentials:1 urn:av-openhome-org:serviceId:Credentials /Credentials/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /Credentials/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /Credentials/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:av-openhome-org:service:Radio:1 urn:av-openhome-org:serviceId:Radio /Radio/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /Radio/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /Radio/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:av-openhome-org:service:Receiver:1 urn:av-openhome-org:serviceId:Receiver /Receiver/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /Receiver/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /Receiver/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xml urn:schemas-tencent-com:service:QPlay:2 urn:tencent-com:serviceId:QPlay /QPlay/4c494e4e-3d9b-11e1-b86c-0016e8030f74/scpd.xml /QPlay/4c494e4e-3d9b-11e1-b86c-0016e8030f74/control.xml /QPlay/4c494e4e-3d9b-11e1-b86c-0016e8030f74/event.xmlUPnP devices found : 1
Device #0: ID 0x0 : LUMIN T2:LUMIN
Model name: T2
Max. memory for audio buffers: 7938MB
Local Audio Engine: CoreAudio
Local devices found : 4
Device #0: ID 0x6b 内建输出
Model UID: AppleHDA:7
UID: AppleHDAEngineOutput:1F,3,0,1,2:0
Model name: Apple Inc. 内建输出
Device #1: ID 0x62 内建线路输出
UID: AppleHDAEngineOutput:1F,3,0,1,3:1
Model name: Apple Inc. 内建线路输出
Device #2: ID 0x59 内建线路输出
UID: AppleHDAEngineOutput:1F,3,0,1,4:2
Device #3: ID 0x55 内建数码输出
UID: AppleHDAEngineOutput:1F,3,0,1,5:3
Model name: Apple Inc. 内建数码输出
