White noise when playing a radio with a 3DLab via UPnP
Hello,
I am using a 3DLab transport nano V5 streamer which works very well for playing music from Quobuz.
Firmware version UpToDate: 2022-06-29
However, I have a few problems when I am playing radio stations.
For example: Radio Paradise’s Mellow with these formats:
  • Flac. 44100 HZ stereo. 1411 kb/s
  • aac. 44100 Hz. stereo. 320 kb/s
  • mp3.44100 Hz. stern 320 kb/s
The radio plays for a few seconds, then the music is replaced by white noise.
The higher the quality, the faster the problem.
Hello @Antoine, I understand you have a 3DLab stremer at Audirvana! Could you try to reproduce the issue?
Thank you
Audirvana Studio 2.9.5 (20905)
Windows 11 (22631) x86_64 with 16GB physical RAM
Connected account of : ****
Available network interfaces:
M&M’s ({41e1db37-f836-4b72-afd5-cdef24c4788e}) is private
Active profile types: all
Private profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Sync list: 0 folders
Sort and display order: en_US
Library database path: C:\Users\raifer\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 1936
Listening on 192.168.1.15 on port 59768
Font size: regular
Language: Français
Ma Musique
Radios
Podcasts
Streaming
Startup view: Ma Musique : Albums
Number of paired remotes: 3
Screen saver disabled: no
Active method: UPnP
Selected Network interface: Wi-Fi
Wi-Fi
vEthernet (Default Switch)
vEthernet (WSL (Hyper-V firewall))
Preferred device: [UPnP] NanoPlayer (UPnP/DLNA) Model UID:JF Light Industries UpMPD UID:uuid:c81a13ce-7c23-f5fd-035d-e45f01b1937d
Selected device:NanoPlayer (UPnP/DLNA)
Manufacturer: JF Light Industries
Model name: UpMPD
Model UID: JF Light Industries UpMPD
UID: uuid:c81a13ce-7c23-f5fd-035d-e45f01b1937d
UPnP device at http://192.168.1.35:49152/uuid-c81a13ce-7c23-f5fd-035d-e45f01b1937d/description.xml
Volume control: Yes
Max volume alert: Disabled
Raw DSD (msb)
UPnP set capabilities
Maximum PCM bitdepth set: 24
Maximum DSD rate set: DSD128
Avoid RAW PCM streams: No
http-get:
:application/flac:*
http-get::application/x-flac:
http-get::application/ogg:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/aif:
http-get::audio/aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/matroska:
http-get::audio/x-matroska:
http-get::audio/mp1:
http-get::audio/mp3:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-ape:
http-get::audio/ape:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::audio/x-wavpack:
http-get::video/mp4:
DLNA 1.5: No
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
NrTracks: 1
MediaDuration: 00:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
Current transport actions:
Next,Previous,Play
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 NanoPlayer (UPnP/DLNA) JF Light Industries https://framagit.org/medoc92 UPnP front-end to MPD UpMPD 42 https://framagit.org/medoc92/upmpdcli/code/ upmpdcli version 1.5.16 libupnpp 0.21.0 mpd 0.22.4 image/png 64 64 32 /uuid-c81a13ce-7c23-f5fd-035d-e45f01b1937d/icon.png /uuid-c81a13ce-7c23-f5fd-035d-e45f01b1937d/presentation.html uuid:c81a13ce-7c23-f5fd-035d-e45f01b1937d urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /uuid-c81a13ce-7c23-f5fd-035d-e45f01b1937d/urn-schemas-upnp-org-service-AVTransport-1.xml /uuid-c81a13ce-7c23-f5fd-035d-e45f01b1937d/ctl-urn-schemas-upnp-org-service-AVTransport-1 /uuid-c81a13ce-7c23-f5fd-035d-e45f01b1937d/evt-urn-schemas-upnp-org-service-AVTransport-1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /uuid-c81a13ce-7c23-f5fd-035d-e45f01b1937d/urn-schemas-upnp-org-service-RenderingControl-1.xml /uuid-c81a13ce-7c23-f5fd-035d-e45f01b1937d/ctl-urn-schemas-upnp-org-service-RenderingControl-1 /uuid-c81a13ce-7c23-f5fd-035d-e45f01b1937d/evt-urn-schemas-upnp-org-service-RenderingControl-1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /uuid-c81a13ce-7c23-f5fd-035d-e45f01b1937d/urn-schemas-upnp-org-service-ConnectionManager-1.xml /uuid-c81a13ce-7c23-f5fd-035d-e45f01b1937d/ctl-urn-schemas-upnp-org-service-ConnectionManager-1 /uuid-c81a13ce-7c23-f5fd-035d-e45f01b1937d/evt-urn-schemas-upnp-org-service-ConnectionManager-1
UPnP devices found : 1
Device #0: NanoPlayer (UPnP/DLNA)
Location: http://192.168.1.35:49152/uuid-c81a13ce-7c23-f5fd-035d-e45f01b1937d/description.xml
Model name: UpMPD
Max. memory for audio buffers: 8192MB
Device #0: Speaker/HP (Realtek High Definition Audio(SST))
Manufacturer: Realtek
Model UID: INTELAUDIO\FUNC_01&VEN_10EC&DEV_0285&SUBSYS_17AA225C&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{57779e52-475f-4e70-8dbe-47f19eb3374d}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: Intel High Definition Audio
J’ai pu échanger avec 3DLab et ils ont pu reproduire le problème de leur côté.
Ils indiquent qu’il s’agit d’un problème au niveau d’Audirvana et il devait vous contacter.
@Antoine, avez vous eu un retour et pu avancer / reproduire le problème?
Bonjour @HTox,
Avec la dernière mise à jour de Audirvāna Studio et en activant l’option “Correctif pour les appareils avec des arrêts de lecture intempestifs”, avez-vous toujours le problème?
Bonjour,
désolé de mon temps de réponse sur le sujet. Avec la dernière version d’AS et l’option activée, le problème persiste.
Vous n’arrivez pas à reproduire de votre côté?
Ils ont réussi à reproduire chez 3DLab.
Merci
Est-ce que vous avez rencontré ce problème sur d’autres radios que Radio Paradise Mellow Mix?
Toutes les radios Paradise. Je peux essayer quelques autres radios avec le même format pour voir.
Hi!
I have same issue. Renderer is Moode upmpdcli, when i’m playing 192khz tracks from Tidal and local i have also noise. About 5 second playing music and then noise comes in instead of music.
Hi again!
Issue was caused by the set of static ip of PC. I change to DHCP and it starts working without interruptions.
But it’s strange why the hell static ip causing such a problems, when it gets subnet mask, gateway and DNS as when i’m enter it manually. I only change ipv4 address to 192.168.0.74 and it’s outside of router dhcp pool.
The issue is also when i’m map static ip via mac for PC in router settings.
Hi, this IP story is really very strange. Maybe you had a IP conflict on the network.
I check every device and i don’t have ip conflict. DHCP i have from 192.168.0.5 to 192.168.0.49.
Do you have a 3DLab nano transport or player?
Today i was play 3 songs in 192khz and 30 seconds before end of third song noise was comes in. I lost hope.
@HTox
No, Audirvana is on PC, and renderer is Moode audio on Rpi 4, DAC is FiiO K5 Pro.
Do you get the same behavior with version 2.10 of Audirvāna Studio?
Hi @Antoine,
I’ve installed the last version.
With this version, I no longer get white noise. Good news.
Unfortunately, now, I have some playing interruption with this same radio.
I’ve tried to activate:
but, no effect.
Do you want a new debug info or log which could help you?
Yes, please
