After the latest version installation?
Very frustrated. Seems like I need to edit, fix, correct with every new update. Quick and simple fix or you can have my money. I’m bailing out.
D.
D.
Hello @tourtelot,
Please remove the line corresponding to your logged-in account to avoid displaying your email address and first name/last name publicly.
Yes. On further veiwing. It seems that AS picks the first song of almost every album and displays it as another album choice. Thus, for any album, there are two copies displayed in the Mac OSX app. One the complete album, let’s say tracks 1 through 10, and another, showing the same artwork, etc but only track one. I have almost 3000 albums and to delete one copy from each album is a huge task.
Doug
Audirvana Studio 1.8.1 (10801)
macOS 10.13 with 16GB physical RAM
AUTO: /Volumes/MUSIC/MUSIC/iTunes Music
iTunes/Music library synchronization: last synchronized on Sun Oct 31 10:44:12 2021
Library database path: /Users/tourtelot/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 56472
Exclusive access: Disabled
PRO-JECT PRE BOX S2 DIGITAL
Model UID:Pre Box S2 Digital:2772:0230
UID:AppleUSBAudioEngine:Pro-Ject:Pre Box S2 Digital:14100000:1
Active Sample Rate: 96kHz
ID 0x2c Pre Box S2 Digital
Manufacturer: Pro-Ject
Model Name: Pro-Ject Pre Box S2 Digital
Model UID: Pre Box S2 Digital:2772:0230
UID: AppleUSBAudioEngine:Pro-Ject:Pre Box S2 Digital:14100000:1
Stream ID 0x2d 2 channels starting at 1
20 virtual formats:
20 physical formats
Local devices found : 5
Device #0: ID 0x4d Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:83 UID: AppleHDAEngineOutput:1B,0,1,2:0 Model Name: Apple Inc. Built-in Output
Device #1: ID 0x2c Pre Box S2 Digital Manufacturer: Pro-Ject Model UID: Pre Box S2 Digital:2772:0230 UID: AppleUSBAudioEngine:Pro-Ject:Pre Box S2 Digital:14100000:1 Model Name: Pro-Ject Pre Box S2 Digital
Device #2: ID 0x35 Pro Tools Aggregate I/O Manufacturer: Apple Inc. Model UID: com.Avid.ProToolsAnalogIOAggregateDevice UID: com.Avid.ProToolsAnalogIOAggregateDevice Model Name: Apple Inc. Pro Tools Aggregate I/O
Device #3: ID 0x43 Dante Virtual Soundcard Manufacturer: Audinate Model UID: com_audinate_dante_driver_NetworkAudioDevice:Dante Virtual Soundcard UID: com_audinate_dante_driver_NetworkAudioEngine:0 Model Name: Audinate Dante Virtual Soundcard
Device #4: ID 0x3d ZoomAudioDevice Manufacturer: zoom.us Model UID: zoom.us.zoomaudiodevice UID: zoom.us.zoomaudiodevice.001 Model Name: zoom.us ZoomAudioDevice
Hmm. And I tried to delete my email. ??
Doug
Not too late, I’d edit the post (email address) now if I were you.
Can you remove the iTunes synchronization to check if your duplicates are not from this double sync?
It changed things, definitely. But I still have a lot of duplicates. The difference is, now the duplicates have the same amount of tracks in them.
Doug
Hello @tourtelot,
I took a look at your database and saw some duplicates but in fact they may are ghost files that has been made because you changed the folder name or moved the file in a different folder like this one below:
Which one it the right one?
J’ai plein de duplications alors que je n’ai qu’un dossier avec les albums d’une artiste, cela s’est passé en refreshant le dossier synchro cela ne part pas et mes fichiers n’ont jamais bougé, heureusement pour moi j’utilise surtout Qobuz
J’espère à chaque livraison que le bug partira mais non…
