Why do some DACs / Bridges get certain features?
Hi
Recently moved from having a iFi Zen Stream as my streaming transport / bridge to a HoloAudio Red streamer
I have very mixed playlists of various formats, sample rates and bit depths. For some reason changing between say 44.1 and 48 kHz on some tracks or between DSD and FLAC gives my DAC (MScaler / Hugo TT2) indigestion
So the ‘Additional Latency when changing spl Rate’ Feature is really, really essential to not have my speakers spewing loud static a few times in a listening session
With the Zen Stream that option for ‘Additional Latency when changing spl Rate’ was there - but now for the HoloAudio Red as the Bridge its gone.
Can someone help me understand how it is there for some DACs / Bridges and not for others?
This and several other buggy aspects of Audirvana (mainly the fact that many of the play customization features in the remote app such as ‘Play Next’ and ‘Add to Playlist’ just don’t work for me - returning ‘request errors’ even when sat next to the router, have had me looking at ROON.
I am using both currently in a bake off and had I not discovered the inferior sound quality of ROON (so far) in my system - I would be now looking to move away from Audirvana because the ROON interface customizability and consistent features set as well as a remote that just works are currently superior
I would love to get to the bottom of why the remote app is broken for me and why the ‘Additional Latency when changing spl Rate’ is not available with some bridges as I would prefer to stay with Audirvana
Note: When you click on the Debug Info button, Audirvana automatically copies all its content. Please paste it in response to this message
So it’s not just a dac but MScaler+dac … to try to narrow the issue remove the MScaler from the chain to verify if the issue is still there
Hi - Yes its still there whether I go in through the MScaler or the Hugo TT2 directly
Audirvana Studio 2.8.2 (20802)
Windows 11 (22631) with 64GB physical RAM
Connected account of :
Available network interfaces:
Ethernet ({c5581ad3-8f83-4bf3-8803-59a690da895b}) is private
Active profile types: all
Private profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Sync list: 0 folders
Library database path: C:\Users\blade\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 1103
Listening on 192.168.x.x on port 57398
Font size: large
Show album covers in tracks list: no
My Music
Radios
Podcasts
Streaming
Startup view: My Playlists
Number of paired remotes: 2
Screen saver disabled: no
Active method: UPnP
Preferred device: [UPnP] Red_192.168.x.x-UPnP/AV Model UID:JF Light Industries UpMPD UID:uuid:e2d52413-455f-fcb3-ca63-d83add6ddbbb
Selected device:Red_192.168.x.x-UPnP/AV
Manufacturer: JF Light Industries
Model name: UpMPD
Model UID: JF Light Industries UpMPD
UID: uuid:e2d52413-455f-fcb3-ca63-d83add6ddbbb
UPnP device at http://192.168.x.x:49152/uuid-e2d52413-455f-fcb3-ca63-d83add6ddbbb/description.xml
Volume control: Yes
Max volume alert: Disabled
Raw DSD (msb)
UPnP set capabilities
Maximum PCM bitdepth set: 24
Maximum DSD rate set: DSD512
Avoid RAW PCM streams: No
http-get:
:application/flac:*
http-get::application/x-flac:
http-get::application/ogg:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/aif:
http-get::audio/aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/matroska:
http-get::audio/x-matroska:
http-get::audio/mp1:
http-get::audio/mp3:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-ape:
http-get::audio/ape:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::audio/x-wavpack:
http-get::video/mp4:
DLNA 1.5: No
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
2 ch Integer PCM 16bit little endian 705.6kHz finite length
2 ch Integer PCM 24bit little endian 705.6kHz finite length
2 ch Integer PCM 16bit little endian 768kHz finite length
2 ch Integer PCM 24bit little endian 768kHz finite length
2 ch DSD 8bit little endian in 8bit chunk 22579.2kHz finite length
NrTracks: 1
MediaDuration: 00:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
Current transport actions:
Next,Previous,Play
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 Red_192.168.x.x-UPnP/AV JF Light Industries https://framagit.org/medoc92 UPnP front-end to MPD UpMPD 42 https://framagit.org/medoc92/upmpdcli/code/ upmpdcli version 1.8.9 libupnpp 0.26.3 mpd 0.23.5 image/png 64 64 32 /uuid-e2d52413-455f-fcb3-ca63-d83add6ddbbb/icon.png uuid:e2d52413-455f-fcb3-ca63-d83add6ddbbb urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /uuid-e2d52413-455f-fcb3-ca63-d83add6ddbbb/urn-schemas-upnp-org-service-AVTransport-1.xml /uuid-e2d52413-455f-fcb3-ca63-d83add6ddbbb/ctl-urn-schemas-upnp-org-service-AVTransport-1 /uuid-e2d52413-455f-fcb3-ca63-d83add6ddbbb/evt-urn-schemas-upnp-org-service-AVTransport-1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /uuid-e2d52413-455f-fcb3-ca63-d83add6ddbbb/urn-schemas-upnp-org-service-RenderingControl-1.xml /uuid-e2d52413-455f-fcb3-ca63-d83add6ddbbb/ctl-urn-schemas-upnp-org-service-RenderingControl-1 /uuid-e2d52413-455f-fcb3-ca63-d83add6ddbbb/evt-urn-schemas-upnp-org-service-RenderingControl-1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /uuid-e2d52413-455f-fcb3-ca63-d83add6ddbbb/urn-schemas-upnp-org-service-ConnectionManager-1.xml /uuid-e2d52413-455f-fcb3-ca63-d83add6ddbbb/ctl-urn-schemas-upnp-org-service-ConnectionManager-1 /uuid-e2d52413-455f-fcb3-ca63-d83add6ddbbb/evt-urn-schemas-upnp-org-service-ConnectionManager-1
UPnP devices found : 3
Device #0: AFTGAZL-15[DLNA]
UID: uuid:beab1ea7-2a98-4056-9dc8-7223a545d38d
Manufacturer: SoftMedia Inc.
Model name: AirReceiver
Device #1: Kitchen Zipp
UID: uuid:7bc7a8f1-bd8b-462e-b25a-fa463b4f2f79
Manufacturer: Libratone
Model name: LTH
Device #2: Red_192.168.x.x-UPnP/AV
Location: http://192.168.x.x:49152/uuid-e2d52413-455f-fcb3-ca63-d83add6ddbbb/description.xml
Model name: UpMPD
Max. memory for audio buffers: 12018MB
Local Audio Engine: ASIO 2
Driver version 2
Local devices found : 3
Device #0: ASIO Chord 1.05
Manufacturer:
Model UID: ASIO Chord 1.05
Model name: ASIO Chord 1.05
Device #1: foo_dsd_asio
Manufacturer:
Model UID: foo_dsd_asio
UID: foo_dsd_asio
Model name: foo_dsd_asio
Device #2: Realtek ASIO
Manufacturer:
Model UID: Realtek ASIO
UID: Realtek ASIO
Model name: Realtek ASIO
Chromecast devices found : 1
Device #0: AFTGAZL-15[Cast]
Can you post the debug info once you have your Zen Stream selected?
Hi Antoine
My Zen Stream is no longer in use - its been replaced by the Holo Audio Red - but here is a summary posted to you earlier in the month that has the Zen Stream in use
Audirvana Studio 2.8.1 (20801)
Private profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Tracks with no MBID: 2162
Listening on 192.168.x.x on port 63022
Font size: regular
Language: English
My Music
Radios
Podcasts
Streaming
Active method: UPnP
Preferred device: [UPnP] iFi zen stream Model UID:iFi audio iFi audio UID:uuid:ca3f1797-449f-3de3-5db8-42a10b471455
Selected device:iFi zen stream
Manufacturer: iFi audio
Model name: iFi audio
Model UID: iFi audio iFi audio
UID: uuid:ca3f1797-449f-3de3-5db8-42a10b471455
UPnP device at http://192.168.x.x:49153/description.xml
Volume control: No
Raw DSD (msb)
http-get::application/flac:
DLNA 1.5: No
Volume Control: None
NrTracks: 1
MediaDuration: 0:01:31
CurrentURI: http://192.168.x.x:49152/audirvana/audio_f_190.wav
CurrentURIMetadata:
dc:titleWallpaper</dc:title>
dc:creatorThomas Newman</dc:creator>
upnp:artistThomas Newman</upnp:artist>
upnp:genre</upnp:genre>
upnp:albumArtURIhttp://192.168.x.x:49152/audirvana/artwork_0_190.jpg</upnp:albumArtURI>
upnp:albumFried Green Tomatoes: Original Motion Picture Score</upnp:album>
upnp:originalTrackNumber11</upnp:originalTrackNumber>
nextURI: http://192.168.x.x:49152/audirvana/audio_f_191.wav
The Smell of Coffee Thomas Newman Thomas Newman http://192.168.x.x:49152/audirvana/artwork_1_191.jpg Fried Green Tomatoes: Original Motion Picture Score 12 object.item.audioItem.musicTrack http://192.168.x.x:49152/audirvana/audio_f_191.wav
PlayMedium: HDD
Next,Previous,Pause,Stop,Seek
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 iFi zen stream iFi audio https://ifi-audio.com The Audiophile Music Player iFi audio 1.0 https://ifi-audio.com 42 uuid:ca3f1797-449f-3de3-5db8-42a10b471455 image/png 64 64 32 /upmpd/icon.png urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upmpd/RenderingControl.xml /ctl/RenderingControl /evt/RenderingControl urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upmpd/AVTransport.xml /ctl/AVTransport /evt/AVTransport urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upmpd/ConnectionManager.xml /ctl/ConnectionManager /evt/ConnectionManager urn:av-openhome-org:service:Product:1 urn:av-openhome-org:serviceId:Product /upmpd/OHProduct.xml /ctl/OHProduct /evt/OHProduct urn:av-openhome-org:service:Info:1 urn:av-openhome-org:serviceId:Info /upmpd/OHInfo.xml /ctl/OHInfo /evt/OHInfo urn:av-openhome-org:service:Time:1 urn:av-openhome-org:serviceId:Time /upmpd/OHTime.xml /ctl/OHTime /evt/OHTime urn:av-openhome-org:service:Volume:1 urn:av-openhome-org:serviceId:Volume /upmpd/OHVolume.xml /ctl/OHVolume /evt/OHVolume urn:av-openhome-org:service:Playlist:1 urn:av-openhome-org:serviceId:Playlist /upmpd/OHPlaylist.xml /ctl/OHPlaylist /evt/OHPlaylist urn:av-openhome-org:service:Radio:1 urn:av-openhome-org:serviceId:Radio /upmpd/OHRadio.xml /ctl/OHRadio /evt/OHRadio /upmpd/presentation.html http://192.168.x.x:49153/
UPnP devices found : 4
Device #0: iFi zen stream
Model name: LTH
Device #2: AFTGAZL-15[DLNA]
Device #3: Living-Room-LG-OLED
UID: uuid:306ab4d3-c573-d8fa-37eb-cb08ad073477
Manufacturer: LG Electronics.
Model name: LG TV
Max. memory for audio buffers: 8958MB
Local Audio Engine: ASIO -2122219135
Driver version -2122219135
Manufacturer:
Manufacturer:
UID: foo_dsd_asio
Manufacturer:
UID: Realtek ASIO
What you describe is strange, the Additional Latency when changing spl Rate is only available when you are using a local device like a USB connected device. It should be displayed when you are using UPNP device. I will double check this with the team.
Hi @Antoine
Is there scope to add this delayed playout for remote destinations?
Audirvana controls the playout so you could have the delay configureable in Audirvana and then Audirvana delay the playout of the next track to the destination - Streamer, speaker etc?
Both Roon and even Foobar seem to offer this ability and as I say I believe it was available in Audirvana with the Zen Streamer (as I configured it)
One of the other interesting changes I noticed was that the Zen Streamer did not allow for any volume control on the streamer itself by Audirvana
The HoloAudio Red does allow for Audirvana to have volume control over the HoloAudio Red depending on whether I select ‘Hardware’, ‘None’ or ‘Software’ from the HoloAudio Red configuration page
Perhaps the Zen Streamer was treated somehow as a ‘local’ device (it is an Audirvana certified device) and maybe that is why there was the facility to configure a playout delay?
Many thanks
