Wondering why Audirvana always displays a bitrate of 320,000 kbps regardless of the file type played; red book CD, MLP, DSD, etc. I have no limitations whatsoever in any of the audio settings.
This happens when i select a file directly from my music folders on my computer and select ‘open with Audirvana’, however if i select a song that has been imported and is already ‘within’ the Audirvana application this does not happen and the correct bitrate is displayed.
Please, please don’t tell me that i’ve been listening to compressed audio all along and been punished because i prefer the ‘folder view’ method of browsing and selecting my music!!!
You can select files from the Audirvana ‘Folder View’ of the ‘LOCAL’ library/libraries
Please post (cut and paste) your debug report here, so folks can help you the best possible… This is found on the Audirvana drop-down window on the menu-bar or the Debug button of the Help Menu in the account settings window.
It’s an issue related to the play queue when you drag and drop a track to it or using the option Open with option. We will need to fix it but it won’t be done for the 3.5 version as we stopped updating this version. It will however be fixed on Audirvāna Studio/Audirvāna Origin.
Thank you for the explanation Antoine, i will trial Audirvana Origin since it has the folder view option. Just to confirm; when 320,000 kbps is displayed, is that the actual bitrate playing?
