I often cannot delete files from the library as the delete menu is often greyed out for no obvious reasons.
Any suggestions?
Any suggestions?
i would suggest, never delete files in Audirvana window…
remove them from your hard drive instead and put them outside of the sync folder
if you want to keep them in case… less chance to have a bug that way or the ghost files
appearearing or doubles
I know that I can delete files manually. However, I actually think a good playback manager should also include some basic file management included. Audirvana does in theory, but it just hardly ever works.
List by tracks instead of albums, that worked for me.
