On Facebook and hifi forums, it is talked about the resources I use, such as allo usb bridge signature etc. to be installed from the laptop source, that a cleaner sound can be heard when the DAC is connected. I’ve never tried. I can not comment. If such a system is installed, can Audirvana be installed?
On the laptop, yes. Whether you’ll hear improvement, you need to try to be able to tell that.
Roon, for example, I know it’s possible.
You mean Roon endpoint software? You can install UPnP software, which is what Audirvana uses to play to an endpoint.
