Can I use my Windows desktop to run Audirvana Studio connected via ethernet to a dCS Network Bridge when both the desktop and Bridge are connected to the network via ethernet?
Hi @audiojerry,
Yes it should. When you open Audirvāna Studio, you should see your device in the audio output menu as a UPnP output. You will need to select it and play a track in the app and the playback will start on your dCS
