Greetings
How to solve this problem? This is Windows 11.
Thanks in advance
Hi @efi,
Can you take a look at your User Account Control (UAC)?
Type UAC in the search field on your taskbar (If the search field isn’t visible, right-click the Start button and choose Search .)
Click Change User Account Control Settings in the search results.
To enable user account control, drag the slider to the security level recommended by Windows and click OK.
You may be prompted to confirm your selection or enter an administrator password.
Restart your computer for the change to take effect.
Thank you it’s ok now
