Hi friends,
I’m having some trouble playing a DSD512 (.dsf) file on Audirvana. The file is 3.05GB in size, stored locally on an nvme SSD. Other DSD512 files also fail to play.
I have successfully played DSD64/128 files previously. The drivers for the Hugo2 are installed and I’m using the ASIO output. The buffer size is much greater than the file size, so I don’t see that as the issue either.
The DAC is capable of DSD512 and Audirvana reports this too. I’m really struggling to figure this one out, so any help would be greatly appreciated.
Thank you all for your time and help.
DEBUG INFO
Audirvana 3.5.44
Sync list: 0 folders
Library database path: C:\Users\user\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 68648MB
Local Audio Engine:ASIO 2 driver version 2
ASIO Chord 1.05
Model UID:ASIO Chord 1.05
UID:ASIO Chord 1.05
Active Sample Rate: 1411.2kHz
ASIO Chord 1.05 Manufacturer:
Model UID:ASIO Chord 1.05 UID:ASIO Chord 1.05
12 available sample rates up to 1536000Hz
1411200
1536000
2 ch Integer PCM 32bit little endian 1411.2kHz
2 ch Integer PCM 32bit little endian 1536kHz
Device #0: ASIO Chord 1.05 Manufacturer: Model UID: ASIO Chord 1.05 UID: ASIO Chord 1.05
Device #1: Realtek ASIO Manufacturer: Model UID: Realtek ASIO UID: Realtek ASIO
