Arf!
Indeed, I never switch exclusive access off. I donât know if PC users can or cannot.
In Audirvana Studio, no, you cannot disable exclusive access on Windows.
well this means you never had the need to play multiple sources, which seems strange on a normal windows or mac machine
i know we probably all wanna use audirvana as a âhigh end - audio playerâ (or we wouldnt spend money on it) for âmainlyâ our high end system, where most of the time you just wanna exclusivly listen to music
but i would like to use audirvana as my âonlyâ player on my windows machine (since i like it), usable in any situation and not having to resort on other players for example, i dont think this is unreasonable but of course you have your own opinion
No, what it means is, i donât want to listen to multiple sources through my headphones or my main speakers. I let AudirvÄna have them. If I want to hear anything else on my computer, though why I would want to while iâm listening to music I donât know, it can be through the laptops speakers.
This is already possible using Wassupi mode , you just need to enable it through Alexa using the remote in landscape mode.
Two things I am happy about.
!. I use Mac, the mere thought of having to use a PC freaks me out.
! I am happy to use different apps for different purposes, I donât need, or want âone size fits allâ bloatware, iTunes for instance, or Roon, or even AS. Origin is perfect for me.
@OffRode
i think from what i read here this is just possible on the mac version
@reddog1
i really would like try a mac but i dislike apple itself (and laptops compared to PC`s) tho i think macOS is superior to windows for some things like audio or other âprofessionalâ things
well atleast in my case/setup audirvana isnt worth it if its not somewhat âuniversalâ, i normally stream music from a dedicated RPI4 Streamer anyway (but i guess audirvana is mostly a alternative to this exact use case, just for mac/windows) which sounds way superior to Windows (i couldnt A/B test with audirvana yet but my guess is that even audirvana cant make windows superior or as good)
I use Windows. It is not as scary as you might think.
The though of a Mac freaks me out, but probably because my ex has one ![]()
PTS-EX-D ?
Mac is good for us that have been through the mill already with windoze, from 3.1 building my first 286 , networking my companyâŚâŚâŚ.last windows I liked was XP Pro. All down hill from there for meâŚâŚâŚ.admin hell running a network after that. Every update breaks something ugghâŚ.
PTS-EX-D indeed! ![]()
Nah. That is all hearsay. If I look on MacRumors it is all doom and gloom with every update. If I look on a Windows forum it is all doom and gloom too.
I guess it is just what kind of Doom & Gloom you are used to ![]()
Windows 11 is not that bad. In my opinion MacOS and Windows are closer together than apart nowadays.
But of course I am biased, because I have been working as a programmer for Windows OS most part of my life now. Maybe I like self-flagellation.
Berufssicherheit ? ![]()
I prefer rock bottom
I started on PC in the late eighties / early nineties, Built my own, learned a bit about dos, floppy disks, and waiting for hours to load applications from floppies. The first time I got to play with a Mac, I was hooked, stuff generally just works. I not an apple âfanâ , hence Audirvana, which I got into mainly because it wasnât iTunes. Iâve run my entire roadshow from a g4 powerbook, digital projection and DJ software, with no issues. Windows just didnât have the same, in my opinion, logic to it. Itâs all horses for courses, anyway.
