Windows VST3 Installation problems
This is a VST plugin, not a VST3 plugin, you wont be able to use it in Audirvana.
I understand, thanks for checking (the free version is VST3 compatible). Allow me to suggest the publication of a list of plugins recommended by you for AUDIRVANA. I believe that all users would appreciate it very much.
Thank you for your time
