HI,Although my new LS50W2 will give me as output
possibility. I can select them.
However, the songs do not start playing when I select the speakers.
What is not working here?
Check/disable the firewall.
In addition to Bitracer suggestion,
- Check your KEF LS50 W2 has the latest firmware in the KEF APP, if not update.
- Try re-setting the KEF speaker and re-initialising on your wireless system using the KEF app.What version of Audirvana are you using with what operating system?
What is your operating system and Audirvana version?
I have KEF LS50 W2 running on macOS 12.4, Studio 1.13.0 and they work flawlessly. I have seen the issue you have stated however a firmware update and speaker hard reset solved the problem.
