Suddenly AUdirvan Win 10 won’t open. It’s not running. Tried to download and reinstall, got the following message “App installation failed with error message: error 0x80070005: Opening file from location: Audirvana.Audirvana-4118-9484-d80dbb7827cd_3.5.2.0_neutral_~_fec4hfhj3emgj.xml failed with error: Access is denied.”
Please advise. Thanks
Hello @RJeff, which version of Windows 10 are you using (18… /19…) and did you had recent windows updates?
Windows 10, Version 1903 (OS Build 18362.418)
Computer updates automatically.
I had update from Audirvana + to the newest version, but lately, every time I tried to open the new link to Audirvana, nothing happened. I kept getting messages telling me to uninstall Audirvana +, which I did.
When you are in Windows Settings>Applications can you see this?
If its the case that would mean you still have the older version of Audirvana on your Windows 10 device.
No. I can’t find Audirvana anywhere, but I can’t reinstall it.
I rebooted a couple of times and it came back. Never mind.
