When using UPnP sometimes the wrong artwork is sent to the player.
See below
Any idea where does it come from and how to fix it?
Thanks again for your support
See below
Hello @JamesG,
Can you send me a copy of the “Debug Info” while you are connected to your Phantom/Reactor? You can get it in Audirvana Settings>General>Debug Info
Hello Damien,
I’ll send you the debug file as soon as it happens again.
Thanks for your help.
@Antoine
macOS 10.15.5 with 16384MB RAM
AUTO: /Users/jamesgalt/Documents/99-Perso/music
Library database path: /Users/jamesgalt/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: Living room Model UID:Devialet Living room UID:uuid:0467d032-0b66-4cf7-92aa-b381e1af8311
Currently playing to UPnP device at 24 bits 96kHz
UPnP device at http://192.168.1.29:38235/0467d032-0b66-4cf7-92aa-b381e1af8311.xml
ID 0x0 Living room Manufacturer:Devialet
Volume control: No
http-get::application/ogg:
http-get::audio/3gpp:
http-get::audio/3gpp2:
http-get::audio/aac:
http-get::audio/aacp:
http-get::audio/aiff:
http-get::audio/amr:
http-get::audio/amr-nb:
http-get::audio/amr-wb:
http-get::audio/atrac:
http-get::audio/atrac-advanced-lossless:
http-get::audio/flac:
http-get::audio/l16;channels=1;rate=44100:
http-get::audio/l16;channels=2;rate=44100:
http-get::audio/l16;rate=44100:
http-get::audio/l16;rate=44100;channels=1:
http-get::audio/l16;rate=44100;channels=2:
http-get::audio/l16;channels=1;rate=48000:
http-get::audio/l16;channels=2;rate=48000:
http-get::audio/l16;rate=48000:
http-get::audio/l16;rate=48000;channels=1:
http-get::audio/l16;rate=48000;channels=2:
http-get::audio/m4a:
http-get::audio/midi:
http-get::audio/mp4:
http-get::audio/mp4a:
http-get::audio/mp4a-latm:
http-get::audio/mpeg:
http-get::audio/mpeg3:
http-get::audio/mpeg4-generic:
http-get::audio/mpga:
http-get::audio/ogg:
http-get::audio/opus:
http-get::audio/vnd.wave:
http-get::audio/wav:
http-get::audio/wave:
http-get::audio/x-aac:
http-get::audio/x-ac3:
http-get::audio/x-aiff:
http-get::audio/x-flac:
http-get::audio/x-flac+ogg:
http-get::audio/x-m4a:
http-get::audio/x-m4b:
http-get::audio/x-m4p:
http-get::audio/x-mid:
http-get::audio/x-midi:
http-get::audio/x-mod:
http-get::audio/x-mpeg:
http-get::audio/x-mpeg3:
http-get::audio/x-mpequrl:
http-get::audio/x-ms-asf:
http-get::audio/x-ms-wma:
http-get::audio/x-vorbis:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-wav:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
12 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 0:04:55.000
CurrentURI: http://192.168.1.21:49152/audirvana/audio_0_4.wav
CurrentURIMetadata:
dc:titlePhœnix</dc:title>
dc:creatorDaft Punk</dc:creator>
upnp:artistDaft Punk</upnp:artist>
upnp:genreHouse</upnp:genre>
upnp:albumArtURIhttp://192.168.1.21:49152/audirvana/artwork_0_5.jpg</upnp:albumArtURI>
upnp:albumHomework</upnp:album>
upnp:originalTrackNumber5</upnp:originalTrackNumber>
nextURI: http://192.168.1.21:49152/audirvana/audio_1_5.wav
Fresh
Daft Punk
Daft Punk
House
http://192.168.1.21:49152/audirvana/artwork_1_6.jpg
Homework
6
object.item.audioItem.musicTrack
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetMediaInfo_Ext InstanceID in A_ARG_TYPE_InstanceID CurrentType out CurrentMediaCategory NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID X_DLNA_GetBytePositionInfo InstanceID in A_ARG_TYPE_InstanceID TrackSize out X_DLNA_CurrentTrackSize RelByte out X_DLNA_RelativeBytePosition AbsByte out X_DLNA_AbsoluteBytePosition SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode TransportState string STOPPED PAUSED_PLAYBACK PAUSED_RECORDING PLAYING RECORDING TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED CurrentMediaCategory string NO_MEDIA TRACK_AWARE TRACK_UNAWARE CurrentTransportActions string PlaybackStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD RecordStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD PossiblePlaybackStorageMedia string NONE NETWORK PossibleRecordStorageMedia string CurrentPlayMode string NORMAL NORMAL TransportPlaySpeed string 1 RecordMediumWriteStatus string WRITABLE PROTECTED NOT_WRITABLE UNKNOWN NOT_IMPLEMENTED CurrentRecordQualityMode string 0:EP 1:LP 2:SP 0:BASIC 1:MEDIUM 2:HIGH NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 512 CurrentTrack ui4 0 512 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 LastChange string A_ARG_TYPE_SeekMode string ABS_TIME REL_TIME TRACK_NR ABS_COUNT REL_COUNT X_DLNA_REL_BYTE A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 X_DLNA_RelativeBytePosition string X_DLNA_AbsoluteBytePosition string X_DLNA_CurrentTrackSize stringCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 Living room Devialet https://www.devialet.com The best sound in the world Phantom 2.10.0 https://www.devialet.com/phantom-speaker/ N09N00016P307 uuid:0467d032-0b66-4cf7-92aa-b381e1af8311 image/jpeg 32 32 24 /DvltRygelRendererPlugin-32x32x24.jpg image/jpeg 120 120 24 /DvltRygelRendererPlugin-120x120x24.jpg image/png 32 32 24 /DvltRygelRendererPlugin-32x32x24.png image/png 120 120 24 /DvltRygelRendererPlugin-120x120x24.png urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /xml/ConnectionManager.xml /Control/DvltRygelRendererPlugin/RygelSinkConnectionManager /Event/DvltRygelRendererPlugin/RygelSinkConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /xml/AVTransport2.xml /Control/DvltRygelRendererPlugin/RygelAVTransport /Event/DvltRygelRendererPlugin/RygelAVTransport urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /xml/RenderingControl2.xml /Control/DvltRygelRendererPlugin/RygelRenderingControl /Event/DvltRygelRendererPlugin/RygelRenderingControl DMR-1.51UPnP devices found : 1
Device #0: ID 0x0 Living room UID: uuid:0467d032-0b66-4cf7-92aa-b381e1af8311 Location: http://192.168.1.29:38235/0467d032-0b66-4cf7-92aa-b381e1af8311.xml
Device #0: ID 0x4b MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
Happened another time
UPnP device at http://192.168.1.29:45971/0467d032-0b66-4cf7-92aa-b381e1af8311.xml
Volume control: No
DLNA 1.5: Yes
12 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 0:05:45.071
CurrentURI: http://192.168.1.21:49152/audirvana/audio_0_113.wav
CurrentURIMetadata:
dc:titleVeridis Quo</dc:title>
upnp:genre</upnp:genre>
upnp:albumArtURIhttp://192.168.1.21:49152/audirvana/artwork_0_114.jpg</upnp:albumArtURI>
upnp:albumDiscovery</upnp:album>
upnp:originalTrackNumber4</upnp:originalTrackNumber>
nextURI: http://192.168.1.21:49152/audirvana/audio_1_114.wav
Short Circuit
Daft Punk
Daft Punk
http://192.168.1.21:49152/audirvana/artwork_1_115.jpg
Discovery
5
PlayMedium: NETWORK
Device #0: ID 0x0 Living room UID: uuid:0467d032-0b66-4cf7-92aa-b381e1af8311 Location: http://192.168.1.29:45971/0467d032-0b66-4cf7-92aa-b381e1af8311.xml
What is the firmware version you have ?
I have the 2.10.0 which is the latest.
Thanks for helping!
Cheers
We previously contacted them towards UPnP implementation and they will work on this during the summer. Do you experience the same behavior with BubbleUPnP?
As I don’t have any android device I cannot test bubbleUPnP
