Hi!
I have problem with interrupting songs and on the end total stop of some songs.
I connect my Yamaha cdn500 as uPnP sound source in Audirvana. Audirvana installed on miniMac.
Is this fix this issue with some additional settings in Audirvana or how? I restart router and switch, i changed ethernet cable…but nothing…
Have you tried revert to version 2.4?
Many things happened not in a good way on 2.5.x and on
you don’t need Dropbox to download the link… just close the windows… and download free.
But I have IOS, not Windows
Do you have installation of Audirvana Studio 2.4 for IOS?
That is the link i gave you
i know you on a mac…
not ios but macos
Voxxx70
October 29, 2023, 10:25pm
8
I did it. With 2.4 ver no problem. Thank you!
Hi @Voxxx70 ,
did you got the issue you described using the 2.5.4 version?
Voxxx70
October 30, 2023, 5:06pm
10
Where I can find 2.5.4 ver? With ver 2.4 work better but not good…after 2-3 songs all stop.
Antoine
October 31, 2023, 8:46am
11
Hi @Voxxx70 ,
Simply click on the spinning arrow in your Audirvāna Studio settings under My account section (picture from a Mac, on Windows you can click on “Check for update”):
Voxxx70
November 4, 2023, 10:45pm
12
I solved my problem on harder way. I installed on my miniMac Windows 10 and everything working fine.
Probelm is non-compatible version of Audirvana and MacOS.
I need some other suggestion from you. I have PC with some DSD files. How to connect miniMac with my PC by network (Local subdirectory in Audirvana)?
system
Closed
February 2, 2024, 10:46pm
13
