Hi
thanks for your help. Yes I bought a used device. On the other end it seems quite fine from the point of view of specifications. At the end I was able to reset the NP, but I have another problem. In fact it works only mono, with one channel. I looked the debug setting and I observed this parameters. Could you suggest me which parameters I have to change and the new values, please?
Thanks and regards
Gianfranco
Audirvana Mac Version 3.5.33 (3563)
macOS 10.13.6 with 24576MB RAM
Registered to Gianfranco Pallanza
AUTO: /Users/gianfranco/Music/iTunes/iTunes Media/Music
iTunes/Music library synchronization: last synchronized on Mon Apr 13 14:50:45 2020
Library database path: /Users/gianfranco/Documents/AudirvanaPlusDatabaseV2.sqlite
TIDAL: Connected as PREMIUM
Max. memory for audio buffers: 21504MB
NP-S2000
Model UID:YAMAHA CORPORATION NP-S2000
UID:uuid:9ab0c000-f668-11de-9976-00a0de72d654
ID 0x2d Built-in Output Manufacturer:Apple Inc.
Model UID:AppleHDA:130 UID:AppleHDAEngineOutput:1F,3,0,1,2:0
DEVICE AUDIO CHANNELS
PREFERRED STEREO CHANNELS L:1 R:2
CHANNEL BITMAP: OX3, LAYOUT:
CHANNEL 0 MAPPED TO 0
CHANNEL 1 MAPPED TO 1
AUDIO CHANNELS IN USE
NUMBER OF CHANNELS: 2
USE AS STEREO DEVICE ONLY: NO
SIMPLE STEREO DEVICE: YES
1 OUTPUT STREAMS:
NUMBER OF ACTIVE CHANNELS: 2, IN 1 STREAM(S)
CHANNEL #0 :STREAM 0 CHANNEL 0
CHANNEL #1 :STREAM 0 CHANNEL 1
Stream ID 0x2e 2 channels starting at 1
4 virtual formats:
16 physical formats
Device #0: ID 0x2d Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:130 UID: AppleHDAEngineOutput:1F,3,0,1,2:0
