YAMAHA R-N2000A via UPnP-unable to skim through a track
I would like to report that high-resolution streaming (Qobuz, Tidal) in the home network with Audirvana Studio direct via UPnP to a YAMAHA R-N2000A works excellently. The nice thing about this is that the track displays are shown on the receiver’s display. The MBP 2016 used is well suited, the waveform spectrum of the amplitudes is also displayed in the Touch Bar (mirrored).
Since I’m under stress with the duration of Audirvane’s trial, I was a bit euphoric in my post. However, the following is not working, which I could use:
When you click on the waveform graph during playback with the mouse, the cursor keeps jumping to the current position, you’re unable to skim through a track!
and a strange behavior:
Jumping back to the previous title only works if you have first jumped forward …
Here in the case of Qobuz streaming, some debug info below:
Audirvana Studio 2.6.0 (20600)
macOS 12.7.1 with 16GB physical RAM
Listening on 127.0.0.1 on port 59895
Active method: UPnP
Preferred device: [UPnP] Saloon Model UID:Yamaha Corporation R-N2000A UID:uuid: …-
Currently playing to UPnP device at 24 bits 192kHz
Selected device:Saloon
Manufacturer: Yamaha Corporation
Model name: R-N2000A
Model UID: Yamaha Corporation R-N2000A
UPnP device at http://192.168.2.115:49154/MediaRenderer/desc.xml
14 available sample rates up to 192000Hz
8000
11025
12000
16000
22050
24000
32000
Volume control: Yes
DSD capability: Raw DSD (msb)
UPnP set capabilities
Maximum PCM bitdepth set: 24
Maximum DSD rate set: Disabled
Avoid RAW PCM streams: No
… up to …
http-get:*:audio/l16;channels=2;rate=96000:dlna.org_pn=lpcm
DLNA 1.5: Yes
Native Gapless playback: No
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
24 virtual formats:
0 physical formats
Hi @hungryfish,
Can you send the whole debug info, there is an important information in it I need to look for.
