Hi
Mystical problem with Audirvana studio and Yamaha AV. No sound in right surround channel with multichanne FLACS when sampling rate is 88.2 while other sampling rates 96 and 192 works. Old Audirvana works with all sampling rates.
Problem exist with both wasapi and kernal.
Yamaha have 5.2.1 (atmos) configuration and connected to PC by HDMI. Problem exist with all PC audio settings like 5.1, Dolby Atmos and 7.1
Attched log file (5.1 configration)
Best Regards
Kari
Audirvana Studio 1.8.7 (10807)
Windows 11 (22000) with 16GB physical RAM
Phase minimum phase
AUTO: D:\Hires
Library database path: C:\Users\Installer\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 2001:14ba:14fa:9b00:502e:b41c:f502:8224 on port 61710
TIDAL: Connected as FREE
Max. memory for audio buffers: 4592MB
Local Audio Engine: WASAPI
5 - RX-V6A (AMD High Definition Audio Device)
Model UID:MMDEVAPI\AudioEndpoints
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{60242bec-96a7-44b8-aa7c-a82ac9ae99be}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 48kHz
Manufacturer: Microsoft
Model Name: 5 - RX-V6A (AMD High Definition Audio Device)
Model UID: MMDEVAPI\AudioEndpoints
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{60242bec-96a7-44b8-aa7c-a82ac9ae99be}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Multichannel: 6 channels
Channel bitmap: Ox3f, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Number of channels: 6
Simple stereo device: No
Number of active channels: 6, in 1 stream(s)
6 ch Integer PCM 16bit little endian 44.1kHz
6 ch Integer PCM 20bit little endian aligned high in 32bit chunk 44.1kHz
6 ch Integer PCM 24bit little endian aligned high in 32bit chunk 44.1kHz
6 ch Integer PCM 16bit little endian 48kHz
6 ch Integer PCM 20bit little endian aligned high in 32bit chunk 48kHz
6 ch Integer PCM 24bit little endian aligned high in 32bit chunk 48kHz
6 ch Integer PCM 16bit little endian 88.2kHz
6 ch Integer PCM 20bit little endian aligned high in 32bit chunk 88.2kHz
6 ch Integer PCM 24bit little endian aligned high in 32bit chunk 88.2kHz
6 ch Integer PCM 16bit little endian 96kHz
6 ch Integer PCM 20bit little endian aligned high in 32bit chunk 96kHz
6 ch Integer PCM 24bit little endian aligned high in 32bit chunk 96kHz
6 ch Integer PCM 16bit little endian 176.4kHz
6 ch Integer PCM 20bit little endian aligned high in 32bit chunk 176.4kHz
6 ch Integer PCM 24bit little endian aligned high in 32bit chunk 176.4kHz
6 ch Integer PCM 16bit little endian 192kHz
6 ch Integer PCM 20bit little endian aligned high in 32bit chunk 192kHz
6 ch Integer PCM 24bit little endian aligned high in 32bit chunk 192kHz
Device #0: 5 - RX-V6A (AMD High Definition Audio Device) Manufacturer: Microsoft Model UID: MMDEVAPI\AudioEndpoints UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{60242bec-96a7-44b8-aa7c-a82ac9ae99be}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: 5 - RX-V6A (AMD High Definition Audio Device)
UPnP devices found : 6
Device #0Makuuhuone RX-V UID: uuid:9ab0c000-f668-11de-9976-00a0decfe9e3 Location: http://192.168.1.101:49154/MediaRenderer/desc.xml
Device #1oh uusi UID: uuid:9ab0c000-f668-11de-9976-608d2638f0f0 Location: http://192.168.1.119:49154/MediaRenderer/desc.xml
Device #2DMR-BCT74 UID: uuid:4D454930-0300-1000-8000-20C6EB895AC8 Location: http://192.168.1.112:60607/20C6EB895AC8/Server1/ddd
Device #3BD-S681 UID: uuid:140479c0-58f3-1cef-84bf-00a0dec5ad2e Location: http://192.168.1.130:2870/dmr.xml
Device #4foobar2000 Renderer (Installer) [DESKTOP-5C50BPU] UID: uuid:ca7c00c6-3408-791c-b1c0-315b0bc2a3cb Location: http://192.168.1.133:1355/
Device #5BRAVIA KDL-32W705B UID: uuid:00000000-0000-1010-8000-fcf152ab26da Location: http://192.168.1.128:52323/dmr.xml
