Audirvana cannot find my WXAD10. No problems with Roon.
Dump the debug info here. Try also with JRiver, just to check that the connectivity using UPnP is there.
Well it Canāt find my Limetree Bridge either. Things like this is what really makes me think about giving up on Audirvana completely.
Audirvana 3.5.41
SoX with 2x upsampling
Anti-aliasing = 99
Manual: (OFFLINE) E:\Musik
Library database path: C:\Users\Tofsen\Desktop\Audirvana support\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 2098MB
Local Audio Engine:ASIO 2 driver version 2
ASIO4ALL v2
Model UID:ASIO4ALL v2
UID:ASIO4ALL v2
ASIO4ALL v2 Manufacturer:
Model UID:ASIO4ALL v2 UID:ASIO4ALL v2
4 available sample rates up to 192000Hz
Device #0: ASIO4ALL v2 Manufacturer: Model UID: ASIO4ALL v2 UID: ASIO4ALL v2
Device #1: Technics ASIO USB Driver Manufacturer: Model UID: Technics ASIO USB Driver UID: Technics ASIO USB Driver
UPnP devices found : 1
Device #0[TV]UE46ES7005 UID: uuid:0f7f4901-0004-1000-95ed-f47b5e1be2a3 Location: http://192.168.10.131:7676/smp_18_
Audirvana 3.5.41
AUTO: D:\Emusic
Library database path: C:\Users\janch\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4726MB
Local Audio Engine:WASAPI
Speakers (Realtek High Definition Audio)
Model UID:Speakers (Realtek High Definition Audio)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{be98b406-15f4-4a0a-91d1-d1563938d4f2}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 48kHz
Speakers (Realtek High Definition Audio) Manufacturer:
Model UID:Speakers (Realtek High Definition Audio) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{be98b406-15f4-4a0a-91d1-d1563938d4f2}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Simple stereo device: No
Device #0: Speakers (Realtek High Definition Audio) Manufacturer: Model UID: Speakers (Realtek High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{be98b406-15f4-4a0a-91d1-d1563938d4f2}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Realtek Digital Output (Realtek High Definition Audio) Manufacturer: Model UID: Realtek Digital Output (Realtek High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{e12b1726-7462-4c81-8059-1d54eee630e4}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Audirvana found 5KPlayer and listed it under Network. Iām also using Twonky Server om my W10 PC. Streaming through WXAD10 and iOS Mconnect app.
Hello @wxad10,
Can you check the firewall settings? In Settings > Update and Security > Windows Security > Firewall and Network Protection > Allow an application through firewall, make sure that Audirvana is allowed to access the network.
Should I try the same thing?
You can also check it, yes
Thing is that I got like 13 Audirvana here, and some of them are boxed both private and public, while some just got private.
Should I delete all but one?
You donāt need to delete them, make sure they are all on boxed for private.
Done. But itās still dosenāt find anything in network devices.
Can you download the app BubbleUPnP on your smartphone? Can you try to use it to play a track using UPnP to your device?
Hmm. I canāt find the Limetree in Bubble either. So far itās only the Lindemann app that can find itā¦
Okay, you may contact the manufacturer of the Limetree to understand what is going on, it can be a bug in their UPnP implementation.
Okay, same as above, can you download the app BubbleUPnP on your smartphone? Can you try to use it to play a track using UPnP to your device?
Installed BubbleUPnP and managed to find my Yamaha streamer. It worked until i restarted Audirvana on my iPhone. Now gone again. Playing and changing songs worked, but skipping in a song did not work.
Waiting for AirPlay support.
