So, I’ve managed to find yet another problem with Audirvana playing Qobuz files.
Qobuz - Prince - Parade (Music from the Motion Picture Soundtrack…)
Track 5, ‘Girls and Boys’ is meant to segue in time straight into track 6 ‘Life can be so nice’. It doesn’t. The timing is completely messed up. You’ll have to listen to the CD to hear how it goes. The beat essentially continues from one track to the next. Streamed via Audirvana (or through Qobuz’s own app) it doesn’t. Not good.
There are several Prince albums which make use of either a continuous ~45 mins of music nominally split into songs, but actually one single uninterrupted piece of music (LoveSexy) or where some tracks connect to others (Parade, Sign ‘o’ the Times). I haven’t tried all of them yet. I don’t hold out much hope. These are 20/30 year old pieces of music which modern streaming is mangling. I’m not very impressed.
Audirvana Mac Version 3.5.29 (3559)
macOS 10.15.2 with 16384MB RAM
Registered to Dominic Perry
SoX
SW volume control: ON
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Wed Aug 28 15:05:43 2019
Library database path: /Users/Dominic/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4454MB
Exclusive access: Disabled
Integer mode: Disabled
Universal Audio Thunderbolt
Model UID:com_uaudio_driver_UAD2System:Universal Audio Apollo
UID:com_uaudio_driver_UAD2AudioEngine:0
Active Sample Rate: 192kHz
Sample rate switching latency: 0.5s
ID 0x43 ADI-2 Pro (55670186) Manufacturer:RME
Model UID:ADI-2 Pro (55670186):2A39:3FD2 UID:AppleUSBAudioEngine:RME:ADI-2 Pro (55670186):76FAF50D19B70C8:1,2
Stream ID 0x44 2 channels starting at 1
20 virtual formats:
20 physical formats
Local devices found : 4
Device #0: ID 0x35 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:128 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x3f HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:128 UID: AppleHDAEngineOutputDP:0,1,0,1,0:0:{6904-27A1-01010101}
Device #2: ID 0x43 ADI-2 Pro (55670186) Manufacturer: RME Model UID: ADI-2 Pro (55670186):2A39:3FD2 UID: AppleUSBAudioEngine:RME:ADI-2 Pro (55670186):76FAF50D19B70C8:1,2
Device #3: ID 0x29 Pro Tools Aggregate I/O Manufacturer: Apple Inc. Model UID: com.Avid.ProToolsAnalogIOAggregateDevice UID: com.Avid.ProToolsAnalogIOAggregateDevice
