Audirvana stops and starts during playback. It is some kind of buffering problem as the loading progress bar in the track graphic shows that the data is downloaded and gradually the playback reaches the loading point and audio stops. Then the read gets ahead and playback starts again. You can see that the download is not reading far enough ahead of playback.
I have tried increasing and reducing the âmemory allocated for track pre-loadingâ from 1GB to 6GB but it doesnât help.
The internet connection is fibre and plenty fast enough to download the music data.
Here is my Debug Info dump:
Audirvana Studio 2.4.0 (20400)
Windows 10 (19045) with 8GB physical RAM
Connected account of : Delwyn Keller
r8brain with Power Of Two upsampling
AUTO: D:\OneDrive\Music
Library database path: C:\Users\Keller\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 2960
Listening on 192.168.0.116 on port 52704
Max. memory for audio buffers: 1072MB
Local Audio Engine: ASIO 2
Driver version 2
Combo384 ASIO 1.03
Model UID:Combo384 ASIO 1.03
Device: 16ch 32bits Integer, 64 bytes per frame 176.4kHz
Active Sample Rate: 176.4kHz
Selected device:Combo384 ASIO 1.03
Manufacturer:
Model name: Combo384 ASIO 1.03
Model UID: Combo384 ASIO 1.03
17 available sample rates up to 45158400Hz
1411200
1536000
2822400
5644800
11289600
22579200
45158400
DSD capability: Raw DSD (MSB)
Multichannel: 16 channels
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 mapped to 6
Channel 7 mapped to 7
Channel 8 mapped to 8
Channel 9 mapped to 9
Channel 10 mapped to 10
Channel 11 mapped to 11
Channel 12 mapped to 12
Channel 13 mapped to 13
Channel 14 mapped to 14
Channel 15 mapped to 15
Number of channels: 16
Simple stereo device: No
16 ch Integer PCM 32bit little endian 44.1kHz
16 ch Integer PCM 32bit little endian 48kHz
16 ch Integer PCM 32bit little endian 88.2kHz
16 ch Integer PCM 32bit little endian 96kHz
16 ch Integer PCM 32bit little endian 176.4kHz
16 ch Integer PCM 32bit little endian 192kHz
16 ch Integer PCM 32bit little endian 352.8kHz
16 ch Integer PCM 32bit little endian 384kHz
16 ch Integer PCM 32bit little endian 705.6kHz
16 ch Integer PCM 32bit little endian 768kHz
16 ch Integer PCM 32bit little endian 1411.2kHz
16 ch Integer PCM 32bit little endian 1536kHz
16 ch DSD 8bit big endian in 8bit chunk 2822.4kHz
16 ch DSD 8bit big endian in 8bit chunk 5644.8kHz
16 ch DSD 8bit big endian in 8bit chunk 11289.6kHz
16 ch DSD 8bit big endian in 8bit chunk 22579.2kHz
16 ch DSD 8bit big endian in 8bit chunk 45158.4kHz
Local devices found : 3
Device #0: ASIO Chord 1.04
Manufacturer:
Model UID: ASIO Chord 1.04
Model name: ASIO Chord 1.04
Device #1: Combo384 ASIO 1.03
Manufacturer:
Device #2: JRiver Media Center 21
Manufacturer:
Model UID: JRiver Media Center 21
Model name: JRiver Media Center 21
UPnP devices found : 2
Device #0: [TV] Samsung Q6 Series (55)
UID: uuid:5d94a574-79ad-4768-8eb4-b03ef8603f8f
Manufacturer: Samsung Electronics
Model name: QA55Q6FNA
Device #1: LUMIN D1:LUMIN
UID: uuid:4c494e4e-3d9b-11e1-b86c-0016e86bd130
Manufacturer: Pixel Magic Systems Ltd.
Model name: D1
