Albums split in two folders
Hi @paulvz,
Can you send a copy of the “Debug Info” when you have this issue? You can get it in Audirvana Settings>My account
Sure, here’s what I got:
Audirvana Origin 2.4.0 (20400)
macOS 13.5.2 with 16GB physical RAM
Connected account of : paul van zwalenburg
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Tue Sep 12 11:56:28 2023
Library database path: /Users/paulvanzwalenburg/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 62879
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
External Headphones
Model UID:Codec Output
UID:BuiltInHeadphoneOutputDevice
Selected device:MacBook Pro Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
ID 0x61
Stream ID 0x62 2 channels starting at 1
4 virtual formats:
4 physical formats
Device #0: ID 0x61 MacBook Pro Speakers
Model UID: Speaker
Hi @paulvz, can please test the sync of folder instead of the iTunes sync? I would like to check if you still experience this split issue when you are only syncing using the folder.
I’m syncing now (after renaming the database) and so far things are looking better, but I do notice that artist names beginning with “The” and similar articles are now sorting based on the first letter of their name, rather than the first non-article letter (so “The Beatles” are now buried deep in my library, rather than showing up in the “B” section). I’m assuming this is related to metadata, and some Apple Music metadata was specifying “Beatles, The” for sorting. Where would I change this for Audirvana. I looked into the General data and see the artist name listed as “The Beatles” - is this where I would edit, or is there another more global location?
Actually, I think I just found the spot by going into Artists view and looking at what I assume is meta data for the artist. Updating the “Sort as” field now…
