I've been using Audirvana 3.2.2 for a long while. Love the software for the most part.
Recently however something puzzling happened. I have roughly 13,000 tracks and hundreds of albums ranging from 44.1 to 2 x DSD. Recently ALL of my cover art
disappeared! All the tracks are still there BUT the window where the album cover art
is usually there is absolutely BLANK! I’ve invested a lot of time editing and organizing
the albums. I cannot seem to find the file to locate all of this info. How can I locate and
reinstall the cover art? I’m using a 2011 Mac mini with Yosemite OS.
Thanks for response. I’m not sure what the external tagging tool is. Sometimes when I purchase music and the files are downloaded incorrectly into Audirvana I do need to edit to correct this. Is that what your referring to? If so then yes I did use it.
Do you have a backup of your Mini?
If you use TimeMachine or another backup software, you will be able to restore the database of Audirvana just as it was before this issue occurred.
One thing you can try is to locate the SQLite file and back it up in different location. After that let Audivana recreate the database from the file metadata. This will only help if the file tags have not been changed.
Yosemite… so you have update to last version of 3.5.50 ?
You are able to play the songs but you cannot see the artwork, correct ?
just try to rebuilt your database with the 3 maintenance options, in order like they are…
Just to be sure, restart mac mini, open Audirvana, no covers?
do the 3 maintenance and see if they come back…
Before you trash the original database, open Audirvana and export every playlist you have if they are important to you with a right click on them or go to the menu and export playlist… to a folder on the desktop or anywhere for you to keep always after yes i know, one by one after sync is done, you can go to menu and import all of them in one shot… export is one at the time if not important to you, don’t bother about playlists…
Close Audirvana.
Go to User… Home Folder (your name)… Library… Applications Support… Audirvana Folder…
copy the file in that folder (AudirvanaPlusDatabase.sqlite), that is your database.
Copy it to the desktop while dragging it hold ‘option’ key on the keyboard…
it will make a copy of the original.
After, drag the original in the trash… you still can see the one you copied on desktop…
empty trash. Restart mac mini, restart Audirvana…
it will now recreate your database with all the changes you made to your file, except your playlists…
it should no be that long… don’t play while it sync, let it go… and see if you see your covers after…
