Hi , downloaded the newest Test Version of Audirvana App
Programm installed correctly , settings are correct, audio is running perfectly
The four blocks of available AU Plugins are not able to use ! No chance to select any of my Plugins !
The Audirvana App crashes every time i double click or try to select one of the four fields " select effect"
No Go !
I honestly do not know why this software constantly shows bugs. It should at least be reasonable, as well as all other audio programs I use.
And just always these super programs, which are supposed to sound better, can not even the simplest things.
As an example, e.g. already the constant error, that this program constantly stops the tracks in the last seconds.
The whole thing does not exactly give an “audiophile” impression.
No one in any studio uses such software full of bugs !
For me, I will not spend money in this “opaque” software. At least once, the basic must work. And that’s what it does with my Logic, Audition, Ableton, etc. Even on my old Mac running El Capitan
Honestly, why i stay with Audirvana is because of the superior sound quality!. The bugs are annoying admittedly so what i do is close ALL apps and RESTART the computer. this allow Audirvana being a resource hungry 3rd party program to play MORE freely. I just can not go back to JRiver or others now. ON a personal note I had wished the menu system worked just like iTunes…
Agree on sound, but when tracks stop randomly it ceases to be a relaxing way to listen. But, I hvae downloaded and tried a bunch of alternatives, and i’ve come to the conclusion that a glitchy audirvana is still better than all else… which does mean the developer can be, and seems to be, a little slow in addressing these issues.
Can you first update to the latest version (3.5.16), and then send me by email or PM the crash report if you still get any crash?
Without such information, it is difficult to investigate…
so now with 3.5.29 the Au plugins are running.
But i can not change the saved preset settings.
Only the last preset is stored and running. I can see all saved presets, but can not change them.
i can adjust every AU Plugin and i can save the preset via the + bar. (user) not local
but when i will choose a second preset nothing will be applied.
