Audirvana crashes reading ISO SACD
Hi,
Using the trial to choose if i’m happy.
Unfortunately when i try to play a ISO file, it takes long time to start it and most of the times it crashes.
I have a lot of DSD files in that format and the software working like that i can’t buy the licence.
The JRiver works just fine with ISO files.
May my settings not setup properly?
I’m working with windows 10 and 4gb ram.
Could you help me, i like very much the sound quality.
Sending the debug details:
Audirvana 3.5.43
AUTO: E:\MUSICA
Library database path: C:\Users\elsoi\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4000MB
Local Audio Engine:ASIO 2 driver version 1106
USB DAC ASIO
Model UID:USB DAC ASIO
UID:USB DAC ASIO
USB DAC ASIO Manufacturer:
Model UID:USB DAC ASIO UID:USB DAC ASIO
2822400
5644800
11289600
22579200
DSD capability: Raw DSD (MSB)
Local devices found : 4
Device #0: ASIO AMI MUSIK DS5 1.03 Manufacturer: Model UID: ASIO AMI MUSIK DS5 1.03 UID: ASIO AMI MUSIK DS5 1.03
Device #1: ASIO4ALL v2 Manufacturer: Model UID: ASIO4ALL v2 UID: ASIO4ALL v2
Device #2: JRiver Media Center 23 Manufacturer: Model UID: JRiver Media Center 23 UID: JRiver Media Center 23
Device #3: USB DAC ASIO Manufacturer: Model UID: USB DAC ASIO UID: USB DAC ASIO
You don’t have that much RAM. Try to reduce the pre-load cache from 4000MB to 1000MB or less.
It could still be a RAM issue, but you can try.
Already done that.
Not very effective, still give me that round blue ribon and if I force it crash.
Anyone who could help me with any solution?
Or I have to give up, unfortunately?
Maybe @Antoine can help you tomorrow. In the meantime, if you have another computer with more memory (RAM), you can try it on that.
You could also consider extracting the individual tracks from the ISO files.
Hello @elso,
Have you tried with WASAPI instead of ASIO?
Hi Damien,
Thanks for your reply.
I tried as you suggest but have the samee issue.
here’s the debug info:
Audirvana 3.5.43
AUTO: E:\MUSICA
Max. memory for audio buffers: 750MB
Local Audio Engine:WASAPI
Speakers (SMSL USB DAC)
Model UID:Speakers (SMSL USB DAC)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{e09b1bff-98c3-4202-86e1-80d2a633a753}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 384kHz
Speakers (SMSL USB DAC) Manufacturer:
Model UID:Speakers (SMSL USB DAC) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{e09b1bff-98c3-4202-86e1-80d2a633a753}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
MQA Decoder device
Simple stereo device: No
Device #0: Philips FTV (Intel® Display Audio) Manufacturer: Model UID: Philips FTV (Intel® Display Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{073c694b-56ff-498d-b5a5-3e777ac07193}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Speakers (SMSL USB DAC) Manufacturer: Model UID: Speakers (SMSL USB DAC) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{e09b1bff-98c3-4202-86e1-80d2a633a753}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Can you send us this track at [email protected]? If the track is 20MB or more, we will send you a link to send it to us.
The track to send is the copy of the debug info?
I mean the ISO track you try to play.
Sorry, now i understand.
The track is from the ISO file album, i can isolate it but in DSF all work fine.
The software do the same to all the tracks when try to play all the vary ISO SACD files.
If you want that i send you the ISO you have to send me the link, it has 1,50gb
Je vois que je suis pas le seul a avoir le problème de lecture des sacd iso , ma question est pourquoi ça marche avec foobar2000 et pas audirvana ?? Avec foobar la lecture ce fait en fraction de seconde , donc ça confirme que le problème ne viens pas de la RAM.
Bonjour @KIMO,
Pouvez-vous m’envoyer une copie de votre “Debug Info” ? Vous le trouverez dans les paramètres d’Audirvana>Général>Debug Info
Remarque: En cliquant sur le bouton Debug Info, Audirvana copie automatiquement tout son contenu, il ne vous reste plus qu’à le coller en réponse de ce message
Hi,
it seems so.
With Jriver i have no problem, the playing of sacd iso is immediately.
In Audionirvana it happens on WASAPI and also on ASIO drivers.
I don’t know if it is a problem of RAM only with Audirvana.
We sent you a message about your issue, did you received it? We would like to know more about the settings your have in your ASIO driver, can you do screenshots of it?
Hi Damien,
Hi already sent you twice, the last in a zip file.
But here they are:
Capture1 Capture2 Capture3 Capture4 Capture5 Capture6
Bonjour Damien,
Je vous ai déjà envoyé débug info il y’a environ 2 ou 3 semaine ainsi qu’un fichier sacd ISO , un test a été effectué chez vous et d’après votre réponse la lecture c’est faite normalement avec votre matériel.
Pour information j’ai un MacBook air, processeur 1,8ghz Intel core i5 double coeur , mémoire 8go 1600 MHz ddr3.et un DAC ifi, et la source de stockage NAS Synology liaison réseau par câble ethernet.
Si vous voulez que je vous renvoie un autre débug info ,ça sera avec plaisir.
Merci a vous
It’s a strange issue.
You have the same problem, and it seems not a problem of RAM
Oui je ne crois pas que ça vient de la RAM , quand je veux lire un sacd ISO la lecture met au minimum 2 minutes à charger c’est énorme , par contre avec foobar ça démarre à la seconde même .
Ce reste un mystère , j’espère que ce problème sera résolu
It hapens the same to me, and most of the times the audirvana crashes while open the Iso.
In Jriver is also in same second that start to play.
With this problem i have to wait to buy my license.
