Hi
I am having similar issues.
As soon as I upgraded to the latest version of Big Sur yesterday (11.3), Audirvana recognises the renderer, load the track, but does not play - stuck at 0.
Chg back to USB, and all Ok. Something in the new Big Sur update is causing an issue with upnp. Nothing else has changed. Was working perfectly for the past few years.
Grant
Debug info belowAudirvana Mac Version 3.5.44 (3574)
macOS 11.3.0 with 8192MB RAM
Registered to Grant Butcher
Max allowed volume: 81.0812
AUTO: /Volumes/music/
Library database path: /Users/grantbutcher/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: CP-800 Model UID:B&W Group Ltd CP-800 UID:uuid:5f9ec1b3-ed59-1900-4530-d81ede20b93c
Currently playing to UPnP device at 24 bits 192kHz
UPnP device at http://192.168.1.16:8080/description.xml
ID 0x0 CP-800 Manufacturer:B&W Group Ltd
Volume control: No
http-wavetunes::audio/x-ms-wma:*
http-get::audio/x-caf:
http-get::audio/x-aiff:
http-get::audio/aiff:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
12 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 88.2kHz
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 88.2kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 176.4kHz
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 176.4kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 48kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 96kHz
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 96kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 192kHz
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 192kHz
0 physical formats
CurrentTransportStatus: ERROR_OCCURRED
NrTracks: 1
MediaDuration: 0:03:48
CurrentURI: http://192.168.1.8:49152/audirvana/audio_0_0.aif
CurrentURIMetadata:
dc:titleTrouble’s Coming</dc:title>
dc:creatorRoyal Blood</dc:creator>
upnp:artistRoyal Blood</upnp:artist>
upnp:genre</upnp:genre>
upnp:albumArtURIhttp://resources.tidal.com/images/b48e332a/2ddf/43ee/aa91/fb704b6e96f9/640x640.jpg</upnp:albumArtURI>
upnp:albumTyphoons</upnp:album>
nextURI: http://192.168.1.8:49152/audirvana/audio_1_1.aif
Oblivion
Royal Blood
Royal Blood
Typhoons
2
object.item.audioItem.musicTrack
PlayMedium: NETWORK
<?xml version="1.0"?>
1
0
SetAVTransportURI
InstanceID
in
A_ARG_TYPE_InstanceID
CurrentURI
in
AVTransportURI
CurrentURIMetaData
in
AVTransportURIMetaData
SetNextAVTransportURI
InstanceID
in
NextURI
in
NextAVTransportURI
NextURIMetaData
in
NextAVTransportURIMetaData
GetMediaInfo
InstanceID
in
NrTracks
out
NumberOfTracks
MediaDuration
out
CurrentMediaDuration
CurrentURI
out
AVTransportURI
CurrentURIMetaData
out
NextURI
out
NextAVTransportURI
NextURIMetaData
out
PlayMedium
out
PlaybackStorageMedium
RecordMedium
out
RecordStorageMedium
WriteStatus
out
RecordMediumWriteStatus
GetTransportInfo
InstanceID
in
CurrentTransportState
out
TransportState
out
TransportStatus
CurrentSpeed
out
TransportPlaySpeed
GetPositionInfo
InstanceID
in
Track
out
CurrentTrack
TrackDuration
out
CurrentTrackDuration
TrackMetaData
out
CurrentTrackMetaData
TrackURI
out
CurrentTrackURI
RelTime
out
RelativeTimePosition
AbsTime
out
AbsoluteTimePosition
RelCount
out
RelativeCounterPosition
AbsCount
out
AbsoluteCounterPosition
GetDeviceCapabilities
InstanceID
in
PlayMedia
out
PossiblePlaybackStorageMedia
RecMedia
out
PossibleRecordStorageMedia
RecQualityModes
out
PossibleRecordQualityModes
GetTransportSettings
InstanceID
in
PlayMode
out
CurrentPlayMode
RecQualityMode
out
CurrentRecordQualityMode
Stop
InstanceID
in
Play
InstanceID
in
Speed
in
TransportPlaySpeed
Pause
InstanceID
in
Seek
InstanceID
in
Unit
in
A_ARG_TYPE_SeekMode
Target
in
A_ARG_TYPE_SeekTarget
Next
InstanceID
in
Previous
InstanceID
in
SetPlayMode
InstanceID
in
NewPlayMode
in
CurrentPlayMode
GetCurrentTransportActions
InstanceID
in
Actions
out
LastChange
string
TransportState
string
STOPPED
PLAYING
PAUSED_PLAYBACK
TRANSITIONING
NO_MEDIA_PRESENT
TransportStatus
string
OK
ERROR_OCCURRED
string
RecordStorageMedium
string
NOT_IMPLEMENTED
string
string
CurrentPlayMode
string
NORMAL
NORMAL
SHUFFLE
REPEAT_ONE
REPEAT_ALL
TransportPlaySpeed
string
1
string
NOT_IMPLEMENTED
string
NOT_IMPLEMENTED
string
NumberOfTracks
ui4
0
1
CurrentTrack
ui4
0
1
1
string
string
string
CurrentTrackURI
string
AVTransportURI
string
string
NextAVTransportURI
string
string
string
string
i4
i4
string
A_ARG_TYPE_SeekMode
string
TRACK_NR
REL_TIME
string
ui4
1
0
DMR-1.50
MS_DigitalMediaDeviceClass_DMR_V001
MediaDevices
BridgecoCE2DM870_0xBD VEN_14E7&DEV_0001&REV_01
Multimedia.DMR
QPlay:1
SeekOnPaused,WHA
CP-800
B&W Group Ltd
CP-800 Stereo Preamp Processor
CP-800
CP-800
D81EDE20B93C
123810928305
image/jpeg
48
48
24
/BCO_device_sm_icon.jpg
image/jpeg
120
120
24
/BCO_device_lrg_icon.jpg
image/png
48
48
24
/BCO_device_sm_icon.png
image/png
120
120
24
/BCO_device_lrg_icon.png
/RenderingControl/desc.xml
/RenderingControl/ctrl
/RenderingControl/evt
/ConnectionManager/desc.xml
/ConnectionManager/ctrl
/ConnectionManager/evt
/AVTransport/desc.xml
/AVTransport/ctrl
/AVTransport/evt
urn:schemas-smsc-com:service:X_WholeHomeAudio:1
urn:schemas-smsc-com:serviceId:X_WholeHomeAudio:1
/WholeHomeAudio/desc.xml
/WholeHomeAudio/ctrl
urn:tencent-com:service:QPlay:1
urn:tencent-com:serviceId:QPlay
/QPlay/desc.xml
/QPlay/ctrl
http://192.168.1.16
UPnP devices found : 6
Device #0: ID 0x0 Marantz SR7011 UID: uuid:1cfe6f03-2860-12cd-0080-0005cd716938 Location: http://192.168.1.13:60006/upnp/desc/aios_device/aios_device.xml
Device #1: ID 0x0 CP-800 UID: uuid:5f9ec1b3-ed59-1900-4530-d81ede20b93c Location: http://192.168.1.16:8080/description.xml
Device #2: ID 0x0 Marantz SR7011 UID: uuid:d7530943-817e-1d6f-0080-0005cd716938 Location: http://192.168.1.13:60006/upnp/desc/aios_device/aios_device.xml
Device #3: ID 0x0 Marantz SR7011 UID: uuid:efdb241a-9da9-101d-0080-0005cd716938 Location: http://192.168.1.13:60006/upnp/desc/aios_device/aios_device.xml
Device #4: ID 0x0 Marantz SR7011 UID: uuid:8453496f-86d0-5bed-7a55-1027014b62c2 Location: http://192.168.1.13:60006/upnp/desc/aios_device/aios_device.xml
Device #5: ID 0x0 Marantz SR7011 UID: uuid:5d8b6568-7163-171f-cdaf-67a744f11c89 Location: http://192.168.1.13:60006/upnp/desc/aios_device/aios_device.xml
Max. memory for audio buffers: 3726MB
Local devices found : 3
Device #0: ID 0x38 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:108 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x3f CP-800 Manufacturer: B&W Group Ltd Model UID: CP-800:19B5:0009 UID: AppleUSBAudioEngine:B&W Group Ltd:CP-800:2144572:1
Device #2: ID 0x2d WiDisplay Loopback Sound Virtual Device Manufacturer: BUGUN Software Co., Ltd Model UID: WiDisplayLoopbackSoundVirtualDevice:WiDisplay Loopback Sound Virtual Device UID: WiDisplayLoopbackSoundVirtualEngine:0
