Audirvana MacOS UPnP problems with Big Sur 11.3
Monterey 12.0 beta is working quite well with AS 1.5.5 for me. Mac Mini-Ethernet or USB, Oppo205, Denon AVR, Pro-ject S2 w/usb
YMMV obviously do a time machine backup so you can go back if needed
Updated to AS 1.5.6
But unfortunately still no fix for the UPnP issues which have been reported by multiple people with many different configurations from May
Can we have some feedback from the developers on this issue and when they think this will be fixed?
Hello @GrantBu ,
Can you send the debug info of Studio in your working Windows 10 setup? We would like to check a couple of things on it. During your tests, have you tried to remove upsampling?
UPnP debug info below for macOS - non working, Will send separate reply for working Windows 10 file
On macOS - I have tried a number of iterations, with both SOX as well as r8Brain, upsampling off as well as the RAW PCM option which was added - off and on, but not been able to get anything to work - press play, shows as file loading all the way through, but does not play.
Audirvana Mac Version 1.5.6 (10506)
macOS 11.4.0 with 8192MB RAM
Bandwidth at 0dB = 99.5%
Anti-aliasing = 91.7194
Phase = 88%
Max allowed volume: 81.0812
Manual: (OFFLINE) /Volumes/music/
Library database path: /Users/grantbutcher/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49290
Preferred device: B&W GROUP LTD CP-800 Model UID:B&W Group Ltd CP-800 UID:uuid:5f9ec1b3-ed59-1900-4530-d81ede20b93c
Currently playing to UPnP device at 24 bits 192kHz
UPnP device at http://192.168.1.25:8080/description.xml
ID 0x0 CP-800
Manufacturer: B&W Group Ltd
Model Name:
Model UID: B&W Group Ltd CP-800
UID: uuid:5f9ec1b3-ed59-1900-4530-d81ede20b93c
Volume control: No
Avoid RAW PCM streams: 0
http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL
http-wavetunes::audio/x-ms-wma:
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320
http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO
http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO
http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_320
http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO_320
http-get::audio/x-caf:
http-get::audio/x-aiff:
http-get::audio/aiff:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
14 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 44.1kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 88.2kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 88.2kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 176.4kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 176.4kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 48kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 96kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 96kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 192kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 192kHz finite length
0 physical formats
CurrentTransportStatus: ERROR_OCCURRED
NrTracks: 1
MediaDuration: 0:06:16
CurrentURI: http://192.168.1.14:49152/audirvana/audio_0.aif
CurrentURIMetadata:
dc:titleDon The Dreamer (Remastered 2020)</dc:title>
dc:creatorKen Wheeler</dc:creator>
upnp:artistKen Wheeler</upnp:artist>
upnp:genre</upnp:genre>
upnp:albumArtURIhttp://resources.tidal.com/images/07920b44/90b6/40aa/9ab0/13ca71a22cb0/640x640.jpg</upnp:albumArtURI>
upnp:albumJourneys In Modern Jazz: Britain</upnp:album>
nextURI: http://192.168.1.14:49152/audirvana/audio_1.aif
nextURIMetadata:
dc:titleA Matter Of Time (Remastered 2020)</dc:title>
dc:creatorDon Rendell Quintet</dc:creator>
upnp:artistDon Rendell Quintet</upnp:artist>
PlayMedium: NETWORK
<?xml version="1.0"?>
1
0
SetAVTransportURI
InstanceID
in
A_ARG_TYPE_InstanceID
CurrentURI
in
AVTransportURI
CurrentURIMetaData
in
AVTransportURIMetaData
SetNextAVTransportURI
InstanceID
in
NextURI
in
NextAVTransportURI
NextURIMetaData
in
NextAVTransportURIMetaData
GetMediaInfo
InstanceID
in
NrTracks
out
NumberOfTracks
MediaDuration
out
CurrentMediaDuration
CurrentURI
out
AVTransportURI
CurrentURIMetaData
out
NextURI
out
NextAVTransportURI
NextURIMetaData
out
PlayMedium
out
PlaybackStorageMedium
RecordMedium
out
RecordStorageMedium
WriteStatus
out
RecordMediumWriteStatus
GetTransportInfo
InstanceID
in
CurrentTransportState
out
TransportState
out
TransportStatus
CurrentSpeed
out
TransportPlaySpeed
GetPositionInfo
InstanceID
in
Track
out
CurrentTrack
TrackDuration
out
CurrentTrackDuration
TrackMetaData
out
CurrentTrackMetaData
TrackURI
out
CurrentTrackURI
RelTime
out
RelativeTimePosition
AbsTime
out
AbsoluteTimePosition
RelCount
out
RelativeCounterPosition
AbsCount
out
AbsoluteCounterPosition
GetDeviceCapabilities
InstanceID
in
PlayMedia
out
PossiblePlaybackStorageMedia
RecMedia
out
PossibleRecordStorageMedia
RecQualityModes
out
PossibleRecordQualityModes
GetTransportSettings
InstanceID
in
PlayMode
out
CurrentPlayMode
RecQualityMode
out
CurrentRecordQualityMode
Stop
InstanceID
in
Play
InstanceID
in
Speed
in
TransportPlaySpeed
Pause
InstanceID
in
Seek
InstanceID
in
Unit
in
A_ARG_TYPE_SeekMode
Target
in
A_ARG_TYPE_SeekTarget
Next
InstanceID
in
Previous
InstanceID
in
SetPlayMode
InstanceID
in
NewPlayMode
in
CurrentPlayMode
GetCurrentTransportActions
InstanceID
in
Actions
out
LastChange
string
TransportState
string
STOPPED
PLAYING
PAUSED_PLAYBACK
TRANSITIONING
NO_MEDIA_PRESENT
TransportStatus
string
OK
ERROR_OCCURRED
string
RecordStorageMedium
string
NOT_IMPLEMENTED
string
string
CurrentPlayMode
string
NORMAL
NORMAL
SHUFFLE
REPEAT_ONE
REPEAT_ALL
TransportPlaySpeed
string
1
string
NOT_IMPLEMENTED
string
NOT_IMPLEMENTED
string
NumberOfTracks
ui4
0
1
CurrentTrack
ui4
0
1
1
string
string
string
CurrentTrackURI
string
AVTransportURI
string
string
NextAVTransportURI
string
string
string
string
i4
i4
string
A_ARG_TYPE_SeekMode
string
TRACK_NR
REL_TIME
string
ui4
1
0
<dlna:X_DLNADOC xmlns:dlna=“urn:schemas-dlna-org:device-1-0”>DMR-1.50</dlna:X_DLNADOC>
pnpx:X_compatibleIdMS_DigitalMediaDeviceClass_DMR_V001
</pnpx:X_compatibleId>
pnpx:X_deviceCategoryMediaDevices
</pnpx:X_deviceCategory>
pnpx:X_hardwareIdBridgecoCE2DM870_0xBD VEN_14E7&DEV_0001&REV_01
</pnpx:X_hardwareId>
df:X_deviceCategoryMultimedia.DMR
</df:X_deviceCategory>
qq:X_QPlay_SoftwareCapabilityQPlay:1</qq:X_QPlay_SoftwareCapability>
smsc:ProductCapSeekOnPaused,WHA</smsc:ProductCap>
CP-800
B&W Group Ltd
CP-800 Stereo Preamp Processor
CP-800
CP-800
D81EDE20B93C
123810928305
image/jpeg
48
48
24
/BCO_device_sm_icon.jpg
image/jpeg
120
120
24
/BCO_device_lrg_icon.jpg
image/png
48
48
24
/BCO_device_sm_icon.png
image/png
120
120
24
/BCO_device_lrg_icon.png
/RenderingControl/desc.xml
/RenderingControl/ctrl
/RenderingControl/evt
/ConnectionManager/desc.xml
/ConnectionManager/ctrl
/ConnectionManager/evt
/AVTransport/desc.xml
/AVTransport/ctrl
/AVTransport/evt
urn:schemas-smsc-com:service:X_WholeHomeAudio:1
urn:schemas-smsc-com:serviceId:X_WholeHomeAudio:1
/WholeHomeAudio/desc.xml
/WholeHomeAudio/ctrl
urn:tencent-com:service:QPlay:1
urn:tencent-com:serviceId:QPlay
/QPlay/desc.xml
/QPlay/ctrl
http://192.168.1.25
UPnP devices found : 1
Device #0: ID 0x0 CP-800 UID: uuid:5f9ec1b3-ed59-1900-4530-d81ede20b93c Location: http://192.168.1.25:8080/description.xml
Max. memory for audio buffers: 3726MB
Local devices found : 3
Device #0: ID 0x3c Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:108 UID: AppleHDAEngineOutput:1B,0,1,2:0 Model Name: Apple Inc. Built-in Output
Device #1: ID 0x38 CP-800 Manufacturer: B&W Group Ltd Model UID: CP-800:19B5:0009 UID: AppleUSBAudioEngine:B&W Group Ltd:CP-800:2144572:1 Model Name: B&W Group Ltd CP-800
Device #2: ID 0x2d WiDisplay Loopback Sound Virtual Device Manufacturer: BUGUN Software Co., Ltd Model UID: WiDisplayLoopbackSoundVirtualDevice:WiDisplay Loopback Sound Virtual Device UID: WiDisplayLoopbackSoundVirtualEngine:0 Model Name: BUGUN Software Co., Ltd WiDisplay Loopback Sound Virtual DeviceDear Grant,
Please find below the debug file for the working Wndows version on AS 1.5.6
Current version: 1.5.6 (10506)
Sync list: 0 folders
Library database path: C:\Users\grant\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 192.168.1.16 on port 56975
Preferred device: B&W Group Ltd CP-800 Model UID:B&W Group Ltd CP-800 UID:uuid:5f9ec1b3-ed59-1900-4530-d81ede20b93c
CP-800
Model Name:
Volume control: No
http-get:
http-get:
http-get:
http-wavetunes:
:audio/x-ms-wma:*
http-get:
http-get:
http-get:
DLNA 1.5: Yes
2 ch Integer PCM 16bit big endian 44.1kHz finite length
2 ch Integer PCM 24bit big endian 44.1kHz finite length
2 ch Integer PCM 16bit big endian 88.2kHz finite length
2 ch Integer PCM 24bit big endian 88.2kHz finite length
2 ch Integer PCM 16bit big endian 176.4kHz finite length
2 ch Integer PCM 24bit big endian 176.4kHz finite length
2 ch Integer PCM 16bit big endian 48kHz finite length
2 ch Integer PCM 24bit big endian 48kHz finite length
2 ch Integer PCM 16bit big endian 96kHz finite length
2 ch Integer PCM 24bit big endian 96kHz finite length
2 ch Integer PCM 16bit big endian 192kHz finite length
2 ch Integer PCM 24bit big endian 192kHz finite length
NrTracks: 1
CurrentURI: http://192.168.1.16:49152/audirvana/audio_0.aif
CurrentURIMetadata:
nextURI: http://192.168.1.16:49152/audirvana/audio_2.aif
A Matter Of Time (Remastered 2020) Don Rendell Quintet Don Rendell Quintet http://resources.tidal.com/images/07920b44/90b6/40aa/9ab0/13ca71a22cb0/640x640.jpg Journeys In Modern Jazz: Britain 2 object.item.audioItem.musicTrack http://192.168.1.16:49152/audirvana/audio_2.aif
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions LastChange string TransportState string STOPPED PLAYING PAUSED_PLAYBACK TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED PlaybackStorageMedium string NETWORK RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string PossibleRecordStorageMedia string CurrentPlayMode string NORMAL NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL TransportPlaySpeed string 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 1 CurrentTrack ui4 0 1 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string A_ARG_TYPE_SeekMode string TRACK_NR REL_TIME A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4
<?xml version="1.0"?> 1 0 DMR-1.50 MS_DigitalMediaDeviceClass_DMR_V001 MediaDevices BridgecoCE2DM870_0xBD VEN_14E7&DEV_0001&REV_01 Multimedia.DMR QPlay:1 SeekOnPaused,WHA urn:schemas-upnp-org:device:MediaRenderer:1 CP-800 B&W Group Ltd CP-800 Stereo Preamp Processor CP-800 CP-800 D81EDE20B93C uuid:5f9ec1b3-ed59-1900-4530-d81ede20b93c 123810928305 image/jpeg 48 48 24 /BCO_device_sm_icon.jpg image/jpeg 120 120 24 /BCO_device_lrg_icon.jpg image/png 48 48 24 /BCO_device_sm_icon.png image/png 120 120 24 /BCO_device_lrg_icon.png urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/evt urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/evt urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/evt urn:schemas-smsc-com:service:X_WholeHomeAudio:1 urn:schemas-smsc-com:serviceId:X_WholeHomeAudio:1 /WholeHomeAudio/desc.xml /WholeHomeAudio/ctrl urn:tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /QPlay/desc.xml /QPlay/ctrl http://192.168.1.25
Device #0CP-800 UID: uuid:5f9ec1b3-ed59-1900-4530-d81ede20b93c Location: http://192.168.1.25:8080/description.xml
Max. memory for audio buffers: 1126MB
Device #0: Speakers / Headphones (Realtek Audio) Manufacturer: Realtek Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0255&SUBSYS_102806AE&REV_1000 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{26445f54-afb9-4e40-bf4e-d0ba2c52a180}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
GrantBu, did you figure anything out? New update today 1.5.7 still no go to my oppo sonica dac with Monterey or Catalina. Bummer
Yep, upgraded to 1.5.7 as well, but also no joy yet
What is odd is that the radio stations work, which to me points out that it could something to do with bit rate.
Recd a mail from @Antoine. Sent some settings to check, but unfortunately still no impact as largely revolved around firewall settings.
Debug file been requested, which I will send through. So on a positive note, this issues getting some attention
Odd results here as well 1.5.7 mac mini Monterey beta Ethernet cabled to Oppo205 tidal plays fairly solid sound is very nice, now the odd part my radio will not stream via Ethernet. Perhaps my settings?
Still nothing to oppo sonica dac lucky it’s close for usb connection.
I suppose we have be waiting a bit longer for upnp. But overall I’m getting all my systems producing good sound. If you are reliant on upnp and wireless it’s a problem
Ok
We have lift off.:grinning:
Upgraded to 1.5.7 on Tuesday, no joy
Just updated to macOS 11.5 and UPNP seems to be working on my system. Tried with SOX and r8Brain and both seem to be working. RAW PCM is switched off.
Will continue with more testing tomorrow, but looking good so far.
Grant, Now you have had a bit of time with it, Do all of the buttons on left side properly switch displays do the radio local radios, high quality etc show properly?
At the top do the my music/ albums populate?
Mac OS 11.5 and UPnP is working. Finally. Now I’m scared to update anything :grimacing:
Hi
All buttons to the left, radio stations, my music and also local music all load correctly.
Occasionally have some issues with slow loading of tracks, but this could be an issue with my network as it is not on all albums when streaming. Will monitor this.
Slow loading appears that it could be a Tidal issue.
Tidal app also has issues with slow loading. Oddly did not pick up an issue with Amarra Luxe.
Looks to have been a Tidal issue.
Buffering issues appear to have now been resolved without any intervention.
macOS11.5 and AS1.5.7 using UPnP playback still working. Not found any serious issues whilst testing.
